Control4 - Common Air conditioners SPLIT ( via IR ) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-14-2012, 03:35 PM - Thread Starter
joaorego's Avatar
I have a model that is not an HVAC system. It is the traditional air conditioners SPLIT. His control is possible via IR (remote control commands).
Is not Ductable
The question is what kind of driver should I try to create. Thermostat?
IR paying attention only sends the signals to the non-return device (temperature), adjusting the temperature control is automatic through its internal Thermostat which is not liable integration.
example:
Init: Temperature - 20 º C (or 68 º F)
Send Command IR # 01 - Up one degree
Send Command IR # 02 - Up one degree
Send Command IR # 03 - Up one degree
Current Temperature: 23 º C (or 73.4 º F)
Mission:
a) Ask the driver to work like a thermostat showing the icon in the default option Comfort (Ascending and Descending degrees)
b) Even in a static way (because the device has internal thermostat keeps the temperature selected via IR) it behaves as a thermostat with all its features.
Has anyone tried to do something?
PS: I got the air conditioner works like a VCR (up and down the volume) up and down degrees. But I do want to take advantage of the interface temperature control.
joaorego is offline
Reply Home Automation
