NEST Thermostat - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-11-2012, 01:43 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 24
I'm going to install a new thermostat (actually three of them) and have been looking at the Ecobee and the NEST, primarily. Does anybody have any experience with either?
I have a single state A/C and heater/furnace. I currently only have four wire running to the thermostat, so no "c" wire. The NEST concerns me just a little because I know it pulls power off the R wire by cycling the furnace. I was wondering if anybody else had a similar setup to see if they liked how NEST works.
The Ecobee looks pretty good technically. It obviously isn't as nice looking and is a bit more expensive.
agogley is offline
post #2 of 4 Old 06-12-2012, 07:36 AM
video321's Avatar
Quoted: 21 Post(s)
I can't comment about either, but I would at least try to fish a wire for a plugin transformer to get your power if you can't get back to the furnance.
video321 is offline
post #3 of 4 Old 06-12-2012, 11:45 AM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 24
I was thinking that. I have only four wires and was trying to figure out how difficult it would be to pull a five wire in its place. However, the ecobee seems to only need four wires since there is a card installed at the furnace where power is connected.
agogley is offline
post #4 of 4 Old 06-12-2012, 12:13 PM
MMMorish's Avatar
Has anyone successfully integrated a Nest with a Crestron system? I know the C4 crew is able to but haven't read anything about Crestron yet.
MMMorish is offline
Reply Home Automation
