Is Crestron's iPad wall mount specific to each new generation of iPad's? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-13-2012, 06:02 AM - Thread Starter
MMMorish's Avatar
With Apple continually changing their devices in terms of size, are the wall mounts specific to each new generation or are they generic to accomodate the different sized iPads?
Speaking of wall mounts, are there other generic wall mounts in the market that have the same functionality as the Crestron version at a cheaper price?
MMMorish is offline
post #2 of 4 Old 06-18-2012, 05:08 AM
HCCDesignGuy's Avatar
What do you mean by "function like Crestrons"?
Most companies building docks for the iPad build them with intended bezel replacement capability, so you only need an adaptor rather than them having to build multiple versions of a dock.
Crestrons dock is my favorite as far as one designed for easy removal however at this time I'm unclear how it works with anything but an iPad 2.
That said, I'm sure they'll come up with an iPad 3 adaptor... For a company with such limited market, they can't possibly afford to make multiple versions of a dock.
The iPort stuff, though not inwall, is the most future proof / Los cost option.
HCCDesignGuy is offline
post #3 of 4 Old 06-18-2012, 11:42 AM - Thread Starter
MMMorish's Avatar
Well, I like how Crestron's pushes the iPad into the wall and then pushes the iPad back out when you wish to remove it.
MMMorish is offline
post #4 of 4 Old 06-18-2012, 01:11 PM
weddellkw's Avatar
Actually Crestron lists two models:
IDOC-PAD-DSWC for Gen1
and
IDOC-PAD2-DSWC for Gen 2 & 3
Both available in White and Black.
weddellkw is offline
Reply Home Automation
