In-wall doc for iPod touch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-15-2012, 12:30 AM - Thread Starter
JOJO888's Avatar
Hi gentlemen,
Just need a inwall charger dock for ipod touch 3 or 4.Could you give me some advice? by the way,iport cm-100 or 200 is a little expensive,so I want to buy some charger only dock.
thx
John
JOJO888 is offline
post #2 of 3 Old 06-15-2012, 06:38 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Vidabox makes 'remote' ipad chargers/extenders (moves power source 100 feet away) - could probably be used for iTouch as well.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 3 Old 06-18-2012, 05:59 AM
HCCDesignGuy's Avatar
If the cm100 is too expensive that I can't really think of anything... It's about the cheapest.
HCCDesignGuy is offline
Reply Home Automation
