Wiring an extraction fan to GrafikEye QS? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-18-2012, 04:42 AM - Thread Starter
dongennl's Avatar
Hi there,
DIY enthusiast, I'm thinking of putting one of the new Lutron GrafikEye QS 4 channel units into my bathroom (well, the unit remote, with a keypad in the actual bathroom).
One thing I'm not sure off is whether I can wire the extraction fan directly to the GrafikEye or will this need some sort of interface?? The fan is about 50-75W.
As I was reading the docs for GrafikEye QS it would appear you can switch the channels to non-dim/switched, so wondered if that could work for non-lighting small loads. The install doc says something about not wiring electric motors due to overheating risk, but wondered if that applies to such a small load.
If I do need an interface or something else in between be grateful for pointer as to what that should be. (CE 230V by the way, UK)
Many thanks!
dongennl is offline
post #2 of 3 Old 06-18-2012, 05:48 AM
HCCDesignGuy's Avatar
Yes, as long as you reprogram a load to non-dimming you can connect a fan, fluorescent, or electronic low voltage to a dimmer designed for incandescent light use.
dongennl likes this.
HCCDesignGuy is offline
post #3 of 3 Old 06-18-2012, 05:49 AM
Reply Home Automation
