New home automation help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-10-2012, 07:06 AM - Thread Starter
EpicVegas's Avatar
I just purchased my first home and would like to add a few automation on a budget.
The plan is to be able to control my alarm, ip cameras, thermostat and a few basic dimmers from anywhere.
Alarm:
Currently the home has a ADT system installed without contract. I would like the alarm system to be local only (no contract or 3rd party)
What alarm unit should I purchase to arm & disarm the local system from my phone or ipad? I would like push notifications when a door opens or the alarm trips exc if possible without any 3rd party contract.
In a nut shell I would like to be at work, get a push notification that the alarm has gone off, check my ip cameras for an intruder and call the police all why being away.
IP cameras:
I'm probably going with Foscam FI8910W Ip cameras & will control them via Foscam app on ipad & iphone
Thermostat:
Going with the Venstar T5800 Color Thermostat w/ wifi card. also controlled via ipad & iphone
Zwave controler:
Looking at getting the Aeon Labs Z-Stick Series 2 USB Dongle as a z-wave controller, then using any z-wave app on the ipad to control a few dimmers and outlets.
A few questions:
Is there an App that can control a majority of this system?
Is there a Zwave power strip with individual controllable outlets?
is there a way to control zwave and A/V components with a remote like a Harmony (I know harmony doesn't support zwave other then the 890)
Most importantly will this basic system work?
THANKS FOR ANY HELP!
EpicVegas is offline
Reply Home Automation
