What can I do with Grafik Eye QS "Ecosystem"? - AVS Forum | Home Theater Discussions And Reviews
Old 07-10-2012, 12:59 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
What's up with the Grafik Eye QS with "Ecosystem" - I have seen 8 and 16 zone models.
Do these work with regular loads, or only with special loads?
If I get one, can I still do up to 6 regular loads, then have "special" loads on the remaining zones, or does it only do special loads on all the zones?
I'd love to have more zones in one unit - but I just have regular incandescent loads. Am I looking at the wrong product for this? Do I have to go with a 2/4/6 zone standard Grafik Eye QS?
Lutron stuff is cool, but these kind of basic questions don't seem at all straightforward in their design guides and other literature.
Hardware and System engineer. Enjoy theaters, automation, media and the outdoors.
Love the hobby, but always have to remember to keep family first!
"The Escape Pod" - First Theater Build
danielrg is offline
Old 07-11-2012, 06:40 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
No replies? No worries.
I'll answer my own question.
Well, I found the answer in the Lutron tech docs (with a little help from their technical support)
http://www.lutron.com/TechnicalDocumentLibrary/QSGRJ-xE%20Sub.pdf
The Graphic Eye QS with Ecosystem supports 3 "standard" type zones that support their usual fare of line voltage loads. These three zones can also be configured as EcoSystem loads.
The rest of the zones (4-8 or 4-16) can only control EcoSystem Ballasts or EcoSystem LED drivers, made by Lutron.
So if you have regular loads, and want >6 zones of control, get two or more Grafik Eye units.
Or you could go RadioRA2, control the GE for 6 zones, and use RadioRA2 dimmers on the others. But then scene control becomes a challenge...
danielrg is offline
