Crestron/Savant vs DIY - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 11-18-2013, 01:00 PM
Dean Roddey's Avatar
Quoted: 388 Post(s)
Liked: 294
Originally Posted by greenbone View Post
I live in New Zealand
For a young startup they seem to have solid financial backing .. new headquarters in Austria and big pushes into the UK and now US
We have a lot of customers in NZ. We also have an integrator there, if you would like me to introduce you.
Dean Roddey
Chairman/CTO, Charmed Quark Systems, Ltd
www.charmedquark.com
Dean Roddey is offline
post #32 of 35 Old 11-18-2013, 04:06 PM
vrbrunzr's Avatar
Hi Greenbone,
Could you please share your experience and results of your Loxone installation?
vrbrunzr is offline
post #33 of 35 Old 11-18-2013, 07:14 PM
greenbone's Avatar
I will update with a few photos etc in the next day or two
in the meantime, have a look at some of my experiences in this thread if you havent already:
http://www.avsforum.com/t/1470776/a-little-automation-win-for-me
greenbone is offline
post #34 of 35 Old 11-18-2013, 07:26 PM
greenbone's Avatar
hi Dean
from briefly looking at CQS, it is a windows-based appliance, used as a central server to control smart lights, outlets etc? please correct me if i am wrong
the loxone miniserver, as well as being a central control point, has digital relays onboard. the advantage of this is that any dumb component can be controlled - a regular light bulb fitting, a regular power outlet, cheap solenoids etc
edit: its hard to discuss these things without coming across as going on an offensive - im simply presenting loxones case, as that is the system that made the most sense to me, and obviously people will see advantages in using CQ in their setup
vrbrunzr likes this.
post #35 of 35 Old 11-18-2013, 08:17 PM
Quoted: 388 Post(s)
Liked: 294
Oh, no one thinks you are going on an offensive or anything. With a system like CQC , if you want that sort of stuff, you pair it with something like an Elk, Omni, Lutron, etc... system, which provides the low level hardware (and in some cases security) functions, and you layer CQC on top of it for all of the stuff that those low level systems can't really do. And of course you get to pick the hardware separate from the software, which we would put forward as an advantage, but someone else might argue otherwise, I dunno.
Dean Roddey
Reply Home Automation
