Looking for new Z-Wave dimmers for LED Swapout... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-23-2012, 12:37 PM - Thread Starter
nfmmalice's Avatar
I currently have 8 can lights in my front room on a Lutron Skylark s600 (Single pole) Dimmer. I'm looking to swap the can lights out with LED Can lights (Probably the EcoSmart 14watt dimmable from Home Depot here: http://www.homedepot.com/h_d1/N-5yc1v/R-202670529/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=led+flood&storeId=10051)
The only thing I need to figure out now is a suitable Z-Wave (or insteon, I guess) dimmer to replace the Lutron Skylark S600 with.
Any Ideas?
nfmmalice is offline
post #2 of 7 Old 07-23-2012, 12:53 PM
Super Moderator
markrubin's Avatar
Quoted: 1039 Post(s)
Liked: 2287
I just redid my house with these (Par 38 version)
standard Lutron RadioRA2 dimmers do not recognize these bulbs unless you leave one incandescent bulb in each circuit
suggest you test any new dimmer before you buy a bunch
these bulbs, at $29.00 each, rated for indoor/ outdoor, are excellent
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #3 of 7 Old 07-25-2012, 07:07 PM - Thread Starter
nfmmalice's Avatar
Are there any Zwave Dimmers that WILL work with these bulbs?
I can also go Insteon if needed, but I dont have a whole lot of Experience with Insteon...
post #4 of 7 Old 08-13-2012, 04:42 PM
drew1910's Avatar
Did you find a dimmer that would work?
drew1910 is offline
post #5 of 7 Old 12-29-2012, 02:00 PM
w@ntonsoup's Avatar
So if I put in CA300 dimmers they won't work to control LED bulbs? Uh oh, that spoils my plans.
w@ntonsoup is offline
post #6 of 7 Old 12-31-2012, 11:39 PM
mike mcdaniel's Avatar
Quoted: 17 Post(s)
I'm using ge switches from lowes.
mike mcdaniel is offline
post #7 of 7 Old 01-06-2013, 09:58 AM
humbug2's Avatar
Quoted: 43 Post(s)
Liked: 27
I have many Vizia RF+ indoor and 2 GE outdoor dimmers. The outdoor dimmers leak enough current to faintly light Christmas LED strings with 100 C9 bulbs. I understand that small current leakage in two wire Z-wave dimmers is common. The Vizia dimmers I have are 2-wire and specify a minimum load of 40w.
I tried a supposedly dimmable outdoor greater than 40 W CFL. Not only would it not dim but it screwed up the function of its dimmer module and other things in the same vicinity. Took the bulb back to Home Depot.
"Most people would die sooner than think, in fact they do so."  Bertrand Russell The ABC of Relativity, 1925
humbug2 is offline
Reply Home Automation
