Halogen dimming? - AVS Forum | Home Theater Discussions And Reviews
Old 07-29-2012, 07:16 PM - Thread Starter
lightsareout's Avatar
Can CU10 halogen can lights be dimmed by a Lutron MAW600H-WH switch?
lightsareout is offline
Old 07-29-2012, 08:16 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I'd call Lutron Tech Support, 24/7 service.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 07-29-2012, 09:33 PM
Colm's Avatar
Liked: 94
If you mean GU-10 base 120V halogen lamps, yes. As far as the dimmer knows, they are just the same as 120V incandescent lamps...because they are incandescent.
Colm is offline
Old 07-29-2012, 09:44 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Yes they can (assuming you meant GU-10 Halogen bulbs). Halogens are filament based and should dim just like an incandescent. However, because halogens burn the filament hotter they depend on the tungsten being re-deposited on the filament to achieve a reasonable lifespan. It's for that reason that they shouldn't be used at 60% or less levels for sustained periods. That will shorten their life significantly. (http://www.lighting-fixtures-ceiling-fans.com/halogen_light_bulbs.html)
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 07-30-2012, 05:13 AM
SAM64's Avatar
Liked: 78
SAM64 is offline
