thermostat wire for in ceiling speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-05-2012, 02:10 PM - Thread Starter
zmann's Avatar
We just went through a renovation and trusted our electrician to install the correct wiring for our in ceiling speakers.
Just now I checked out the wires closely and they say: Steren (R) 18/4 AWG CU Thermostat E222992 c(UL) CL2 731271.
It makes me suspicious that I wanted speaker wires and got thermostat wires.
Can anyone educate me, if these wires work at all or if there are any major quality issues regarding the sound with those?
zmann is offline
post #2 of 8 Old 08-05-2012, 03:01 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Wire is pretty much wire. That said, it's generally preferred to use heavier than 18 gauge for speakers. Did he run the 4 conductor cable to each location? If so you could double up by using 2 conductors together for each of the speaker wires, making the wire equivalent to 14 gauge.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 8 Old 08-06-2012, 08:27 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
I'd call him out on it. Unless you didn't give him much guidance, that's a pretty stupid mistake. biggrin.gif
I agree it'll *probably* work, though
NickTheGreat is offline
post #4 of 8 Old 08-06-2012, 08:38 AM
Super Moderator
markrubin's Avatar
Quoted: 1035 Post(s)
Liked: 2273
it will work but sound quality might be seriously compromised
it depends what size speakers and amplifier you have: you will be limited by use of undersized wire: if it is an in wall speaker in a bathroom it might be OK: if they are outdoor speakers by the pool: it will never be right
this is a major mistake by a guy who should know better
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #5 of 8 Old 08-06-2012, 03:11 PM
Colm's Avatar
Liked: 94
Originally Posted by markrubin View Post
...this is a major mistake by a guy who should know better
Assuming an electrician knows anything about the requirements for a speaker system is asking for trouble. If you specify what you want and don't get it, that is one thing. If you don't specify what you want, you get what you get. Seems OP got what he specified: speaker wires. 18 AWG is apparently what the electrician is used to using. Sounds like typical tract home speaker pre-wire to me.
Colm is offline
post #6 of 8 Old 08-06-2012, 03:16 PM
Colm's Avatar
Liked: 94
OP said he ran 18/4.
Colm is offline
post #7 of 8 Old 08-06-2012, 03:22 PM
Colm's Avatar
Liked: 94
The wire is fine for what it is. It is rated CL2 (same as most in-wall speaker cables) which means it is adequate for class 2 circuits, which most speaker cables are. The only noticeable difference may be it is solid wire. Speaker cable is usually stranded. But it really makes no difference for in-wall wire. Stranded wire is better for something that is repeatedly flexed. I doubt you wil be repeatedly flexing your in-wall wire. According to the table on Roger Russels's site. 18 AWG is adequate for a 8 ohm load up to about 32 feet. Double up strands of the 18/4 and it is fine for about double the distance. If the speakers are lower impedance, the distances are reduced.
Colm is offline
post #8 of 8 Old 08-07-2012, 05:41 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
The thermostat wire will work, but unfortunately your electrician did not
cshepard is offline
Reply Home Automation
