IP controlled automation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-26-2012, 02:05 PM - Thread Starter
Whatstreet's Avatar
I am looking for a WIFI controlled IP light switch. Something like Luminode but without the learning jazz. Google promised to enter this market about a year ago but still have not introduced a product.
So far I have found several possibilities.
A relay type device http://www.controlbyweb.com/webrelay/ that can switch 110V AC.
The Good
Web Controlled
The Bad
Bulky and inconvenient form factor. requires CAT cable
Global Cache'
The Good
WIFI Controlled
The Bad
Bulky inconvenient form factor. Switches low voltage so it would need to control an external relay for 110V AC.
Belkin Wemo
The Good
Wifi controlled. iOS software
The Bad
No Android support. Inconvenient form factor. Rumored to be unreliable - looses connection.
That’s all I have so far. Any suggestions for IP controlled home automation will be appreciated.
Whatstreet is offline
post #2 of 10 Old 08-26-2012, 04:21 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
How about Lutron RA2? RF communication from controller to dimmer, wifi communication to controller. Nice looking, high quality. Controller is plugged into an outlet inside a cabinet or closet, or perhaps sitting on a microwave oven.
Not too sure you'd want a dimmer with an IP address. Dedicated RF network is better.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 10 Old 08-26-2012, 04:31 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
This pdf white paper/marketing piece from Lutron explains why a dedicated RF network has its advantages.
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.lutron.com%2FCaseStudyPDF%2FClear%2520Connect%2520Technology%2520whitepaper.pdf&ei=QqI6UIrZBKaK7AG8iID4AQ&usg=AFQjCNHxQaZQdYaBElzkO0uD_kPTIiTc9g
Neurorad is offline
post #4 of 10 Old 09-10-2012, 10:34 AM
DevvonST's Avatar
I would use Lutron as well, since it is IP controlable, scalable and has working control apps and web control.
DevvonST is offline
post #5 of 10 Old 09-11-2012, 05:44 PM
az1324's Avatar
Quoted: 24 Post(s)
Pretty much every automated switch can be connected to the network via some kind of gateway. Lutron is just too expensive and dealer-centric. There are options at < $50 per switch and even that seems pricey when you think of the other technology $50 can buy.
az1324 is offline
post #6 of 10 Old 09-11-2012, 06:31 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Lutron RA2 is 'dealer centric' because Lutron wants it installed by dealers, and not end users. One of the reasons it's pricey is because their products are made in the US. Additionally, Lutron puts a ton of effort into R&D. Lutron stays ahead of the other manufacturers.
If you want high quality, expect to pay for it. Don't say something is too expensive because YOU don't think it's worth it.
Neurorad is offline
post #7 of 10 Old 09-12-2012, 03:47 AM
az1324's Avatar
Quoted: 24 Post(s)
Some of their products are made in China and Mexico too. And their intellectual property is one of the reasons competing products are not priced lower already. I'm not arguing against the business decisions, just offering an opinion. A lot of their mainstream products are priced reasonably, but the automated switches are not among them.
az1324 is offline
post #8 of 10 Old 09-12-2012, 06:15 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Insteon is another option, along with zigbee and zwave.
NicksHitachi is offline
post #9 of 10 Old 09-12-2012, 07:54 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Lutron also has to pay for 24/7/365 phone tech support, from PA (not India).
Neurorad is offline
post #10 of 10 Old 09-12-2012, 08:40 AM
westcojack's Avatar
We use a competing product with Lutrons Radio Ra2, but feel that for what the product does and its use, it is very competatively priced, and IMHO a better choice than power line cariers.
The fact that they have 24/7 tech support is also amazing.
I thought that all Homeworks and RA2 products were made in the US? which are not?
westcojack is online now
Reply Home Automation
