IR Light Switch for 10 Lights - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-27-2012, 12:48 AM - Thread Starter
penti01's Avatar
I currently have the Logitech Harmony One, so my choices are pretty much limited to IR.
My one requirement is that I want one that can control around 10 lights separately (actually, around 20, but some only need one control for 2-3 lights). I've been looking at the Lutron ones, but since I have lots, I don't want to have the switches take up so much space! Looking for something that takes up just one set that can handle all those.
Hope someone can suggest something.
::edit to add: even if it's not necessarily a switch, even if it's just the sensor so it's just controlled by the remote.
penti01 is offline
post #2 of 6 Old 08-29-2012, 05:20 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
I'd start with a different remote.
cshepard is offline
post #3 of 6 Old 08-29-2012, 07:25 PM - Thread Starter
penti01's Avatar
I'd rather not spend for remote light switches AND a new remote, not until I make a new set-up from the ground up..
penti01 is offline
post #4 of 6 Old 08-29-2012, 08:41 PM
sv650s's Avatar
http://www.lutron.com/Products/WholeBuildingSystems/Grafik4000/Pages/Overview.aspx
A 6 load and a 4 load will fill your needs and you then can put scene controllers where ever you want. You trigger scenes on the g eye.
sv650s is offline
post #5 of 6 Old 08-30-2012, 11:52 AM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
Is this for new construction or for retrofit? That can change the answer dramatically...
For new construction, if there's a lot of switches / loads near each other (even in different, adjacent rooms), the GrafikEye is definitely one to look at. If you can utilize a 6 or 8-zone GE setup, it will be cheaper than individual controllable dimmers (or at least, easier to deal with).
Jeff
jautor is offline
post #6 of 6 Old 08-31-2012, 10:19 PM
az1324's Avatar
Quoted: 24 Post(s)
Are all the lights in the same room or are you going to carry around the Harmony?
Some combination of Insteon IRLinc, Switchlinc, InlineLinc may work for you.
az1324 is offline
Reply Home Automation
