Remote controlled door lock - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-28-2012, 08:55 PM - Thread Starter
oapy123's Avatar
I'm looking for a door lock with handle/lever that can be controlled via a number-pad AND keyfob (in my case I need at least 2 keyfobs). So far I've only been able to find one by Morning Industry which gets shotty reviews (especially the remote) and another one by E-Digital/Lockkey which apparently only comes with one remote and theres no information on where to buy another.
I dont care about z-wave or zigbee. Is there nothing better out there?
oapy123 is offline
post #2 of 4 Old 08-29-2012, 04:17 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
cshepard is offline
post #3 of 4 Old 08-29-2012, 05:35 PM - Thread Starter
oapy123's Avatar
Thanks but that is way out of my price range.
oapy123 is offline
post #4 of 4 Old 08-29-2012, 09:12 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
It's hard to find info on stuff that is, for the most part, wholesale only, e.g. electronic security. If you have an alarm system, the controller may provide the key fob or card swipe functionality to an electric strike or automatic lock.
I'd call ASIHome and Smarthome Sales and/or Tech Support, for leads.
Cocoontech forums may be a good place to look and post for ideas.
I think you're looking for a basic commercial access control system, much more expensive than z-wave or other basic Resi product, but a fraction of the cost of C4.
You may just want to pay for a local locksmith who does electronic security. It may save you a lot of time.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home Automation
