Stick with AMX - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-01-2012, 02:01 PM - Thread Starter
Krobar's Avatar
Quoted: 17 Post(s)
Hi All,
I have an NI-3100 and an MVP-7500 that is no longer working well.
Will soon be moving house and have the oppurunity to completely rewire as the "New" house will be a serious rennovation. I am a DIYer and have done some basic AMX on my own (Mainly 2 way rs232 integration of Audio prepro and video processor and touch panel interface). Is AMX still widely being used? I know I can buy an IPAD software solution for the touchpanel but wondered if AMX is worth sticking with just because I have the software and can just about set it up?
Krobar is offline
post #2 of 2 Old 09-02-2012, 11:35 AM
DevvonST's Avatar
Absolutly, AMX is still widely used. I also believe it is the most stable platform on the market, when programmed properly. As for your AMX product, the NI-3100 is still a current controller, but the 7500 is of an age and quality that I would recommend replacing. But as you stated you can use an iPad as a UI running the TPControl app to control your entire system, even remotly. Good Luck...smile.gif
DevvonST is offline
Reply Home Automation
