Any way to use Landmark system with wireless LCD controllers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-16-2012, 09:30 PM - Thread Starter
George7806's Avatar
It's been a while since I've last posted....as the title says, I'm looking for a way to control an existing Landmark based automation system with either wireless LCD screens or Ipad. Since this is a very complex system, and since it is still working as intended, my customer isn't just ready yet, to spend around $70K to upgrade to AMX or Crestron. I've been maintaining the system adding, changing components, changing programming etc. in the past couple of years. I'm looking for a way to have a GUI similar to what I have on the AMX-AXT-LC screen. I'm aware of how limited the options are for this system, but I'm open for any ideas. Besides the A/V equipment, the home has full lighting control by Lutron HWI, shade, door, window control. If more info needed about the existing eqipment, I could provide a full list. Thanks for any ideas!
George7806 is offline
post #2 of 4 Old 10-17-2012, 01:14 AM
az1324's Avatar
Quoted: 24 Post(s)
Ipad, iRule, custom driver, network to RS232 adapter?
az1324 is offline
post #3 of 4 Old 10-17-2012, 06:56 AM - Thread Starter
George7806's Avatar
Thank you, I was not aware of iRule at all, I'll be looking into this solution. Looks quite promising from what I can tell after a few minutes of looking into this.
post #4 of 4 Old 10-25-2012, 01:06 AM
39CentStamp's Avatar
Be sure not to spend too much time on this band aid. You may get to the end of the upgrade and have the Phast system fail making it a waste of time & money.
If the iPad+iRule option will work i would make sure that there is an upgrade path using those products. So lets say the phast system totally dies the day after your upgrade is done. Now what? What switcher or processor etc will work.
Just make sure the current upgrade + the inevitable upgrade later don't end up costing more than moving to a crestron/amx/control4 system now.
As for the GUI...If you are using the iPad the client wont know whats under the hood. Most of the products on the market from $100-$1million dollars have included GUIs or you can buy 3rd party GUIs to use. If you can actually use iRule as a front end to the Phast system it will be pretty amazing. The clients will feel like they got a whole new system.
39CentStamp is offline
Reply Home Automation
