I need a new lighting solution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-29-2012, 02:45 PM - Thread Starter
Ferrisguy's Avatar
any ideas for updating lighting
Currently have 3 X10 wirless switch dimmers. Each are on a single pole set up.
One controls area near mini refrigerator which is right when you enter the room
the sign is controlled by a X10 wireless appliance plug in device
Second one is in a hall way.. two scones lights
third one is in the main room.. controlling four can lights
Motorized Projection Screen (Somfy Motor) w/ RF Remote - Matte White Fabric (106 inch, 16:9) Monoprice item number 6582
needs to be wireless, one remote for all..maybe something that can go to a Logitech remote when i finally up grade that.
Thanks for the help
Ferrisguy is offline
post #2 of 2 Old 10-29-2012, 02:51 PM
DA INFERNO's Avatar
Micasaverde with iRule should work and you can keep your lights. Micasaverde works with X10 and Z-wave and iRule can control Micasaverde.
DA INFERNO is offline
Reply Home Automation
