Suggestions on how to get security camera video from a gate that's 800ft away - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-14-2012, 11:16 AM - Thread Starter
KingFeta's Avatar
I originally wanted to use a Power Over Ethernet camera for my security gate, but the max distance seems to be about 300ft which won't work in my case. How can I get video back to my house at that distance(800ft)? Can I use coax and convert it back to ethernet? Fiber(expensive though)? Thanks.
KingFeta is offline
post #2 of 5 Old 11-14-2012, 01:18 PM
az1324's Avatar
Quoted: 24 Post(s)
You could try HomePlug if you have an existing 120V run you can isolate, MOCA with coax, or you could use some LOS wireless solution.
az1324 is offline
post #3 of 5 Old 11-14-2012, 02:38 PM
holmern's Avatar
You can add PoE extenders for longer distances.
http://www.veracityglobal.com
holmern is offline
post #4 of 5 Old 11-15-2012, 05:52 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
Fiber is likely cheaper, and more reliable in the long run (pun intended). When you're talking about making network connections across distances you also need to consider outside disruptions like lightning and other electrical faults. Using fiber pretty much eliminates that as a risk for your network equipment. Since it's just one camera you really don't need much bandwidth. I'm guessing even a 10 megabit fiber adapter would suffice, but you'll likely find 100mbit more commonly available. That and you don't introduce anything odd. It's just a network connection, not something that's trying to piggyback onto something else. Just be sure to pull a fiber that has double the capacity in the event something breaks. Don't just pull a single pair, pull a two-pair (four strands). That way if anything's wrong with a fiber you'll have two others already pulled.
wkearney99 is offline
post #5 of 5 Old 12-31-2012, 09:01 PM
whatuusay1's Avatar
http://www.veracityglobal.com/products/ethernet-and-poe-extension/longspan.aspx
Long range ethernet (800 meters) with 802.3at POE sources. There are a number of manufactures out there for these type of products :-)
whatuusay1 is offline
Reply Home Automation
