RF remote control light switch support for LED bulb? - AVS Forum
post #1 of 7 Old 11-25-2012, 09:18 AM - Thread Starter
mase1981's Avatar
Hey,
in my theater room i have installed a ceiling LED light bulb.
i have the logitech harmony 1100 with RF emiters.
i was searching the internet and the forum for a specific solution,
i read some but got a lil confused,
i wanted to ask a question for a solution.
i am looking for a single bulb remote control (IR or RF) light switch.
all i could find are remote control switches that support regular bulbs.
i bought one and installed it and it didnt work on my LED light bulb.
is there one out there that has a remote so i can set it up on my logitech that support LED light bulb?
no need for a dimmer (which will prolly cant be since its LED anyhow)
just simple on off with remote for LED bulb.
thank you.
mase1981 is offline
post #2 of 7 Old 11-25-2012, 10:36 AM
az1324's Avatar
Lutron SPSF-S6A
Lutron MRF2-6ANS
mase1981 likes this.
az1324 is offline
post #3 of 7 Old 11-25-2012, 07:04 PM - Thread Starter
mase1981's Avatar
thank you.
from my understanding MRF2-6ANS-BL will be what i need,
am i correct to assume ?
i need the main controller, yes?
if so, do i need a specific RF controller from the manufacture or will it connect to my harmony?
thanks.
mase1981 is offline
post #4 of 7 Old 11-25-2012, 09:36 PM
az1324's Avatar
With the MRF2 you'll need to purchase a pico remote. With the SPSF you should be able to use IR from your harmony.
az1324 is offline
post #5 of 7 Old 11-26-2012, 06:28 AM - Thread Starter
mase1981's Avatar
ok,
so it seems like the SPSF-S6A-BL will be what i want.
but from reading online it is stated that i also need a control panel?
is that true? or will buying this alone (roughly 120$) and simply disconnecting what i have now and installing this instead will work?
also, i understand that the unit does not come with a wall plate, is that true?
mase1981 is offline
post #6 of 7 Old 11-26-2012, 01:10 PM
az1324's Avatar
No you don't need a control panel. However I don't know if Harmony has the proper IR codes in its database so you might need a remote to learn them. It does not include a wall plate but is standard decora. You might want to consider switching your bulbs to dimmable LED so that you can use the cheaper MIR-600THW as well as enjoying the benefits of dimming.
az1324 is offline
post #7 of 7 Old 11-26-2012, 04:40 PM - Thread Starter
mase1981's Avatar
do you think this will work with the MIR-600THW
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=203010504&storeId=10051&langId=-1&catalogId=10053&MERCH=REC-_-SearchPLPHorizontal1-1-_-NA-_-203010504-_-N#.ULQK8ofAdNI
apparently i checked in my house and i have the MIR-600THW at home....
so i can save some money,
do you know if they will play nice?
thank you !!!
mase1981 is offline
Reply Home Automation
User Tag List
