How does CEC work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-01-2013, 05:22 PM - Thread Starter
stefuel's Avatar
Quoted: 40 Post(s)
Liked: 26
I want to take my old projector down which was controlled via serial and replace it with a Samsung UN65ES8000. From a automation point of view, I only see IR as a option. Then it was suggested that CEC might be a option. The AVR in the rack (50 feet away)will provide the audio and all source switching. So all I need to run to this location is one HDMI cable, one ethernet cable and a extension for a IR emmiter (if I use IR). All I really need to do is turn it on/off. So how does CEC work and is it a good option if I only want it for power?
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #2 of 5 Old 01-02-2013, 12:34 AM
SweetSpot's Avatar
Most of the current Samsungs (including the one you listed) have an RS232 (EX-Link) port, so you could simply use that rather than go through the trouble of injected CEC commands--which require even more equipment to do so. If you're controlling with Crestron send me a PM and I can send you a working module.
SweetSpot is offline
post #3 of 5 Old 01-03-2013, 07:59 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Originally Posted by stefuel View Post
So how does CEC work and is it a good option?
Poorly, and no.
cshepard is offline
post #4 of 5 Old 01-04-2013, 10:10 AM
SweetSpot's Avatar
Originally Posted by cshepard View Post
Poorly, and no.
I use CEC control of displays almost exclusively (including some source devices) when working with Crestron DM systems and it works perfectly.
post #5 of 5 Old 01-22-2013, 07:58 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
I didn't read in the OP that he was using Crestron.
cshepard is offline
Reply Home Automation
