Replacement Processor - AVS Forum | Home Theater Discussions And Reviews
Old 01-01-2013, 09:01 PM - Thread Starter
sonarman's Avatar
Much to my chagrin, 7 years in, we discover that Lutron no longer supports our Homeworks Processor, which needs replacement:
Lutron H4P5-H48-HRL-120
Looking for ideas on where we might source a replacement processor, which seems preferable to updating the whole system.
This is a 4 Series P5 Wired Processor with one integral Dimmer Interface (H48) and a Hybrid Repeater Link.
Never contemplated when we initially installed the Lutron system, that wt would not be supported down the road.
sonarman is offline
Old 01-02-2013, 03:48 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I'd hire the guy who installed it, to find the replacement.
Did you try calling Lutron TS?
Are you sure it's broken?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 01-11-2013, 06:30 PM
aberdiel's Avatar
How do you know the proc needs replacement?
aberdiel is offline
Old 01-11-2013, 08:18 PM - Thread Starter
sonarman's Avatar
I stand corrected....at least partially. I did get Lutron help. They accepted that the board is down and through local distributor provided a replacement. Replacement did not support previous H-RFP-2P, so have had to replace that with a HR-REP-120. Not quite there with Illuminations link-up, and awaiting verdict on how much warranty credit Lutron will allow with the processor swap. The basis of our issue may have been more local/distributer in nature. As we are now about 90% back up, feeling better about it.
sonarman is offline
