Are there any simple switched power outlets that work with a 12V trigger? - for sub-woofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-28-2013, 06:13 PM - Thread Starter
metropole's Avatar
Quoted: 39 Post(s)
I am in the process of upgrading my receiver. My current receiver has a switched power outlet. The one doesn't.
However, I like the idea to cut power form my sub when the receiver is off.
Are there any simple switched power outlets that work with the receivers 12V trigger?
metropole is offline
post #2 of 6 Old 01-28-2013, 06:54 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
They are, but not exactly cheap. Niles AC-3:
http://www.nilesaudio.com/product.php?prodID=AC-3&recordID=120Volt%20AC%20Power%20Switching%20Systems&categoryID=Switching%20Systems&catcdID=&prdcdID=FG00242
Does your subwoofer not have an automatic on/off?
jautor is offline
post #3 of 6 Old 01-28-2013, 07:07 PM - Thread Starter
metropole's Avatar
Quoted: 39 Post(s)
I am pretty sure that my sub has an automatic on/off.
post #4 of 6 Old 01-30-2013, 09:57 PM
Totalcontrol's Avatar
We have been using the WattBox line which has full IP control.
Total Control Remotes
www.totalcontrolremotes.com
Totalcontrol is offline
post #5 of 6 Old 01-31-2013, 12:46 PM
jautor's Avatar
Liked: 778
Note that if you're doing this to "save power", the cost of any of these switching devices at >$50 would take years to break even (and that's assuming the sub's standby power isn't a modern <1W standby - ratings for EnergyStar, etc.)
jautor is offline
post #6 of 6 Old 02-01-2013, 09:00 PM
controlguy's Avatar
You could also do something like an AMX PC1. New price is actually a little higher than the Niles (and only through an AMX dealer), but you can usually find them on ebay for $50 or less.
http://www.amx.com/products/PC1.asp
controlguy is offline
Reply Home Automation
