Good small controller - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-03-2013, 09:45 PM - Thread Starter
MattyJo's Avatar
Can anybody recommend a small good and reliable controller? I need to just control a few lights and and a valve. Must be reliable and good quality.
MattyJo is offline
post #2 of 5 Old 02-10-2013, 06:04 PM
AaronCF's Avatar
Not sure of your exact requirements....but check the CommandFusion Mini Starter Pack.
http://www.commandfusion.com/minipack.html
I can be contacted at aaron (at) commandfusion.com if you have any questions.
AaronCF is offline
post #3 of 5 Old 02-10-2013, 06:53 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
Also not exactly what all you want. This will allow for future expansion. You would need a dealer for setup.
http://www.control4.com/residential/products/controllers/HC-250/
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #4 of 5 Old 02-14-2013, 12:54 PM
DaveTheAVDude's Avatar
RTI XP series processors will do the trick nicely. The XP3 retails $500 has relay outputs, 3 routable IR, and RS-232 port.
DaveTheAVDude is offline
post #5 of 5 Old 02-23-2013, 08:56 PM
enstormblue's Avatar
I second the RTI XP Vote, controllers are small and should be able to accomplish what you need pretty easliy
enstormblue is offline
Reply Home Automation
