HAI?? Clare Controls?? worth installing? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-13-2013, 05:15 PM - Thread Starter
elecguyloops's Avatar
Hello I'm looking at a project of 12 duplexes 24 units and wanting to put and automation system in with just audio control (4zone 4source) and basic lighting control, HVAC control. I've been hearing too many bad things about Control 4 and am looking at HAI or Clare Controls.
Any commets or Suggestions on these 2 products?
Thank you!
elecguyloops is offline
post #2 of 4 Old 02-13-2013, 07:09 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Hire an experienced local HAI installer, to help plan it out. At a minimum, to help with design. Install alarm systems too, and you'll get a good deal from the installer.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 4 Old 02-14-2013, 10:24 AM
intuitivehome's Avatar
Definitely should check out Clare. They have a builders box that is for the exact type of job you’re describing, with room to scale up. 4 or 6 zones of cobranet audio…kicks HAI’s butt, IMO. You can contact them through their website to get info on becoming or locating a dealer.
intuitivehome is offline
post #4 of 4 Old 02-14-2013, 11:35 AM
az1324's Avatar
Quoted: 24 Post(s)
Says the new member (::cough:: clare rep) who joined the forum just to post that. Doesn't mean it couldn't be true, but grain of salt.
az1324 is offline
Reply Home Automation
