Need guidance with x10 lighting and setting scenes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-18-2013, 02:07 PM - Thread Starter
johnny wadd's Avatar
Hello everyone, first off I want to thank all of you ! I've been lurking around this sight for some time now; always looking for tips and tricks and let me tell you, you guys have really helped me!
But, I'm trying to determine the best way to have scene control with my current set up.
Harmony 1100 remote
IR543 powerhouse to covert IR to x10
3 soft start, dimming light switches.
I want to create scenes.. movie lights, romantic, etc..
Can I buy an 8 button smart home keypad LINC 12064W, use a maxi controller to program the keypad for scenes, and then use my harmony remote (via IR543) to send the signal to select scenes?
Or do I need software is. Active home to do this?
Any help / guidance would be appreciated
johnny wadd is offline
Reply Home Automation
