New home - need some info - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-19-2013, 08:18 AM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
Hi all,
I don't know what I am looking for in particular, but wanted to get some ideas from you guys as to what can be done n term of automation for our new home.
Again, I don't know what works and what doesn't so sorry for the stupid questions.
1. can the garage door open automatically as the car approaches?
2. can we install lights that will turn on with motion detection.
3. what other cool automations can be down on low budgets.
sid369 is offline
post #2 of 8 Old 02-19-2013, 10:32 AM
K Shep's Avatar
Originally Posted by sid369 View Post
Hi all,
Yes
Yes
This
Guests may push this button and a bell will chime in your house to inform you of their visit.
K Shep is offline
post #3 of 8 Old 02-19-2013, 11:49 AM
DGF
DGF's Avatar
Liked: 39
You didn't specify what you meant by "low budget" - K Shep's suggestions for a garage door opener and a door bell are certainly possibilities..... - but there are some other neat products around for lighting, convenience and security - check out Smarthome.com for some inspiration (I literally just recommended the same site in a separate post, but have absolutely no affiliations or connections with the company other than being a satisfied customer!). You can do things when the garage door is triggered, such as turn on the lights for the garage, if it's dark, turn on hallway lights from the garage, annouce your arrival, etc. etc. - there are an almost infinite number of possibilities.
DGF is offline
post #4 of 8 Old 02-19-2013, 09:26 PM
tictactoe2004's Avatar
Originally Posted by K Shep View Post
Yes
Yes
This
tictactoe2004 is offline
post #5 of 8 Old 02-21-2013, 03:18 PM
DaveTheAVDude's Avatar
K Shep... Hilarious!
I have integrated RTI, Radio Ra2, and the alarm system to do exactly what you describe. All of the devices in the alarm, ie the motion detectors and door contacts, can trigger macros in the RTI system. Depending on what "low" means, this could be a possibility. Ive done smaller homes for under $10k, and larger homes for $100k+, just depends on what you are looking for.
DaveTheAVDude is offline
post #6 of 8 Old 02-22-2013, 07:22 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You should search Elk M1, Lutron Radio RA2, and HAI OPII as possible hardware.
Cocoontech forums are a good place for research, particularly for HAI and Elk - dedicated subforums.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #7 of 8 Old 03-09-2013, 10:58 AM
haworld's Avatar
Zwave, X-10 and Insteon can do all these things, although X10 is pretty much dead now. Zwave is everywhere in over 750 products all over the world. It is a DIY heaven too, and very affordable.
haworld is offline
post #8 of 8 Old 04-24-2013, 01:23 PM
scottwood2's Avatar
Although the new HA system have many improvements I still find that X-10 still bring a lot of value. I have had a X-10 system for years and still find the devices are way more cheaper that other newer tech items. I see short supply of many x-10 items still so some are still buying it. I am looking at wireless door/window devices. X-10 is $22 for 3 ot them and the batteries last for more than 3 years I am told. Just depend what you want and how deep your pocket book is.
Scott Wood
scottwood2 is offline
Reply Home Automation
