Multiple apps for multiple systems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-24-2013, 08:12 AM - Thread Starter
horsegoer's Avatar
So if I want to wirelessly control my music, hvac and shades using iPhone, tablet etc. I will always be using different apps for each system? If so what is the cheapest way to control everything wirelessly from a single app/interface. We are gutting our house so I will be running wires shortly. We have a 2 family house and we live on 2nd floor so the space is small if that makes a difference. I really need and a/v consultant on LOng Island if anyone knows one....just for advice and to see my space because this is all a little confusing. I will def do the install myself. Thanks
beau
horsegoer is offline
post #2 of 12 Old 02-24-2013, 07:51 PM
ClemsonJeeper's Avatar
Quoted: 228 Post(s)
Liked: 139
I'm planning on using HomeSeer to do this. You either need a Windows box running the software 24/7 or use one of their appliances (which basically has a embedded Windows XP install running their software).
With HSTouch you can design your own iPhone/iPad interfaces and control anything HomeSeer has a plugin for (in my case: security, lights, audio, HVAC, sprinklers, garage doors, and locks).
There are other competitors to HomeSeer such as Vera.
November 2015 HT of the Month: The Vortex Theater
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
post #3 of 12 Old 02-25-2013, 10:23 AM
K Shep's Avatar
On another thread you asked a completely different question that contradicts your question here. You sound confused.
You want everything "the cheapest" and it all to be controlled from a single app. Plus you'd like an A/V consultant, do you plan to pay this consultant then install his design yourself?
K Shep is offline
post #4 of 12 Old 02-25-2013, 05:16 PM - Thread Starter
horsegoer's Avatar
I love condescending people like you....most are miserable. The cheapest...who said that? I said I would pay a consultant to help with ideas only and I would install myself. Problem? Confused I said I was!!!
beau
post #5 of 12 Old 02-25-2013, 05:58 PM
K Shep's Avatar
Read below.
You wrote this below, no where have you mentioned paying a consultant.
Listen horse! I may be miserable but I'm not wasting time. I guess I should be a little nicer when members post non-sense but it's frustrating when I try to help you and in return you post ignorant questions in reply. This is your post from another thread.
What interface is there that I could mount on my wall say in my kitchen that I could control my music if say my computer is not on, and I don't want to use my iPhone? Would it require cat 6? Thanks
You don't mount interface on a wall horse, you load interface on a device in the form of code. But that information is difficult for folks who don't take the time to learn about home systems.
Thank you for loving me, I wish I could say the same.
K Shep is offline
post #6 of 12 Old 02-25-2013, 06:59 PM - Thread Starter
horsegoer's Avatar
Read below.
beau
post #7 of 12 Old 02-26-2013, 06:55 AM
Quoted: 228 Post(s)
Liked: 139
Well, hey, I gave you some ideas for somewhat cheap solutions and you didn't respond to them ... So.....
post #8 of 12 Old 02-27-2013, 04:07 AM - Thread Starter
horsegoer's Avatar
Thanks CJ...looking into Homeseer....did not see your post.
beau
post #9 of 12 Old 02-28-2013, 02:54 PM
colerl102's Avatar
Take a look at MainLobby too... They have a great iPad interface and I have been using it for several years now... Switched from HomeSeer...
colerl102 is offline
post #10 of 12 Old 03-04-2013, 04:15 AM - Thread Starter
horsegoer's Avatar
Wow Coler... ML very expensive
beau
post #11 of 12 Old 03-04-2013, 11:18 AM
DGF
DGF's Avatar
Liked: 39
I dropped many hundreds of dollars on the MainLobby suite and more time than I care to remember - I was able to achieve more in a few hours using Roomie than I ever did with ML. But to be fair, I haven't looked at the MainLobby iOS offerings for a while.
DGF is offline
post #12 of 12 Old 03-04-2013, 01:02 PM
sic0048's Avatar
Cheap and home automation do not belong in the same discussion.
First you have the cost of the hardware. Is all of your equipment controllable (and just because it has a dedicated app doesn't mean that a centralized automation system will be able to control it)?
Then you have the cost of the automation system. Going DIY limits your choices, but allows the end user to control and modify their system instead of having a service tech come out ($$$) to make a change in the system. You've gotten a couple of suggestions already. I personally use Charmed Quark Controller (otherwise known as CQC) as the core of my system. I like their pricing structure much better than some of the alternatives. With CQC, you pay for a license based on the total number of devices you want to control. It doesn't matter what the devices are, and you can change the devices at any time. With most other options, you get charged for each specific device. If you end up changing brands (ie going from a Sony TV to a LG TV), then you have to pay more money to control the new device. With CQC, you can simply unload the old device and load in a new device without having to pay more money because the total number of devices hasn't changed.
Then you have installation costs. If you are going DIY, this may not require a lot of $$$, but it will certainly require a lot of time. The Professionally installed systems certainly cost more, but they are done in a stated time frame without a lot of grief. DIYing an automation system has been fun, but I'm a geek and enjoyed it. Unless you enjoy tinkering (and getting yelled at from the family because something went wrong), you shouldn't attempt to DIY this.
- Brian
CQC user since 2005
SageTV user since 2007
PBX in a Flash user since 2012
sic0048 is offline
Reply Home Automation
