What am I missing here Samsung serial control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-02-2013, 04:55 AM - Thread Starter
stefuel's Avatar
Quoted: 40 Post(s)
Liked: 26
All I'm trying to do here is turn on/off a Samsung UN60ES7500 via the EX-link port from a X-gen (cnmsx-pro) com port. I constructed a cable following the CNSP-568 cable diagram. the tip is RX, the ring is TX and the sleeve is ground. Double checked with a multimeter. I seem to recall that the Crestron com ports are not standard and I think this wiring diagram and the module I pulled the protocol from is for a 2 and 3 series processor. I am sending from "COM C" for ON \x08\x22\x00\x00\x00\x02 and get no results. Is the com port pin-out the same for a x-gen pro and a pro2? Or am I sending the wrong protocol? The com port is set up correctly 9600 baud, parity none, data bits 8 and stop bits 1. Thanks,
Chip
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #2 of 3 Old 03-02-2013, 07:51 AM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
I've never done it, but you might consider connecting to the display from a PC first, using hyperterminal or Hercules, for troubleshooting.
Try searching for Samsung 232 control at RC.
Do you need a carriage return?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 3 Old 03-02-2013, 11:50 AM - Thread Starter
stefuel's Avatar
Quoted: 40 Post(s)
Liked: 26
It's fixed. I was missing the last byte from both strings \0d6 for on and \0d5 for off.
So how was this working in a supposed working module without it??
stefuel is offline
Reply Home Automation
