Ipad as wall mount touchscreen - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 81 Old 12-17-2013, 03:54 PM
tadr's Avatar
Originally Posted by holyindian View Post
Have a quick question guys. Can you keep your iPad or any android pad on when mounted on the wall only to turn off at night, turning off meaning sleep mode or the mode when the tablet need to be awakened with the push of the button. Will it cause the tablet to go bad if it is turned on all the time during day time? Does any one keep it turned on screen mode all the time?
I keep my android tablets on all the time in daydream mode with the click. Touch to wake it up and go to my custom launcher. Works great (so far)
tadr is offline
post #62 of 81 Old 12-23-2013, 03:11 AM
harryofto's Avatar
whatever that means. They also say the iPad 4 sleeve is "coming soon" and the iPad 4 has been out for a long while now -- likely they are having issues with the lightning port. So who knows how long it will take.
ec5F
harryofto is offline
post #63 of 81 Old 02-10-2014, 09:14 PM
avbrett's Avatar
I used a mount from amazon. I flushes into the wall. It's difficult to remove but I like that so it doesn't go missing.
http://www.amazon.com/gp/product/B00GUDZKLU
There's one for the iPad mini too.
avbrett is offline
post #64 of 81 Old 02-11-2014, 07:28 PM
allthetime's Avatar
I don't know what level of customization you are after but...
If you are using a computer with access to wifi as your control, I would highly recommend checking out TouchOSC and the OSC protocol in general.
Here is a very simple example of what it can do... https://www.youtube.com/watch?v=5gEyp1TGS4E
Interfaces are simple-looking and completely customizable.
allthetime is offline
post #65 of 81 Old 03-01-2014, 06:40 AM
vrbrunzr's Avatar
Loxone has a US web shop as well as US support.  Here is link to their wall mount.
http://shop.loxone.com/enus/wallmounts.html
vrbrunzr is offline
post #66 of 81 Old 03-01-2014, 09:44 AM
gadgetfreaky's Avatar
Quoted: 21 Post(s)
I've now had my launchports for a few months. They are definitely worth it. White, with white cases. I have four launchports throughout the house, and 2 ipad mini's. so when there's nothing on them it looks fine, and it's super easy even for my 6yr old to pull it on and off to charge.
gadgetfreaky is offline
post #67 of 81 Old 05-15-2014, 02:07 PM
ojuicy's Avatar
has anyone found a in-wall (not on wall) mount that will fit the old HP Touchpads (besides to $400 iPort). Thanks!
ojuicy is offline
post #68 of 81 Old 05-15-2014, 03:30 PM
haworld's Avatar
How about idocxonline? I don't know much about this stuff, but I saw these today and thought I would share.
haworld is offline
post #69 of 81 Old 07-17-2014, 07:35 PM
bwhitmore's Avatar
Has anyone found a way to hard wire the Launchport Wall station in?
I love the look and functionality of the Launchport, but looking at that stupid plate down below that's simply plugged into an outlet sure is tacky.
There's gotta be a way to hard wire it in so you don't see any wires?
thanks!
bwhitmore is offline
post #70 of 81 Old 07-17-2014, 08:34 PM
FlyingDiver's Avatar
Quoted: 203 Post(s)
Liked: 58
thanks!
The LauchPort gets DC power from it's "wall wart" transformer. I don't see why you couldn't run your own power line (longer than the one they supply) to some other location where you do want to put the transformer (and wall plate). The room on the other side of the wall you want to put the Port on would be easy. Other locations are certainly possible, such as an attic or basement. Just be sure to use in-wall rated wire of an appropriate size for the power. And check the environmental rating of the wall-wart if you decide to put it in the attic, it might not be rated for the temperatures you might get there.
FlyingDiver is online now
post #71 of 81 Old 07-19-2014, 09:45 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
Use a poe type supply.
Run two cat cable to the launch port one for pore and one for data.
SMHarman is online now
post #72 of 81 Old 07-20-2014, 05:44 AM
bwhitmore's Avatar
Interesting idea. Could you please elaborate?
POE is defined as "power over Ethernet?" How would this be done?
post #73 of 81 Old 07-20-2014, 11:15 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
If the end device doesn't support PoE, there's little reason to go through the expense and hassle, since PoE gear isn't inexpensive.
If you're going to run wires anyway, a 2-conductor thermostat wire (basically anything rated for low-voltage and in-wall usage) spliced onto the correct DC plugs at both ends and you're done.
jautor is offline
post #74 of 81 Old 07-24-2014, 10:12 AM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
Yeah, I did not explain this very well.
The back of the launchport looks like this.
There is nothing to stop you running thermostat wire, UL rated speaker wire, CAT5 and connecting it to the two power wires on the back. Running that wire to a remote location and then manking the power connection at the remote location. As many homes of people on this forum have structured cable wired in the walls and have surplus wired in the wall, I was pointing out that you could use one of these to make the power connection to the launchport and only need to cut the wall where the launchport and a suitably close piece of CAT5 are located. No need to fish a new wire through the wall.
https://www.launchport.com/shop/ipad...l-station.html
Even details the AWG of the wire for different run lengths.
Wire Size ChartMax Length Gauge25'24 AWG40'22 AWG60'20 AWG100'18 AWG150'16 AWG
16 AWG is a basic speaker wire such as this from monoprice, good for a ridiculous 250' from launchport to power supply.
http://www.monoprice.com/Product?c_i...seq=1&format=2
CAT5 is 24 AWG so good for that 25' run.
As Jautor points out, true POE is a 48V power supply, what I was talking about was running a CAT5 cable and putting power through it, so 'running power over a spare ethernet cable' not running POE.
post #75 of 81 Old 07-24-2014, 01:44 PM
jautor's Avatar
Liked: 777
Let's coin a new term for everything that came before PoE... DCoC "DC over Category"
And yes, anything with enough AWG and UL ratings will work perfectly fine. And to echo your 'spare' cable suggestion - if you're going to run *something*, cat5e is a really good choice, especially if there isn't one there already...
SMHarman likes this.
jautor is offline
post #76 of 81 Old 11-19-2014, 08:20 AM
AnnapolisSony's Avatar
Quoted: 93 Post(s)
Liked: 136
Ever since I completed my room, I’ve been using an iPad to control things like my Sonos, my OPPO and my Yamaha AVR. My iPad was in a protective case and would either sit up on the bar top or the on the chairs. For the longest time I’ve wanted to mount it in the wall and recently I decided to finally tackle it. Honestly, I was blown away at the prices of some of the iPad wall mounts out there. Some of them even topped $300-$400 (iPort, etc.) which I knew right off the bat I was NOT going to pay.
After going back and forth and back and forth I decided to take a leap and purchase a $99 mount from a guy on eBay. I later found he sells his mount on a website at:
http://www.simplewallmount.com
I needed two things in a wall mount: 1) An attractive looking, easily-removable flush mount with home button exposed 2) Option to hook up a charger/power cable.
This product delivered both and for a fraction of the cost of most others on the market. It actually comes with two face plates so you have a couple of different looks if desired.
I installed it last night and it was a piece of cake. The wall that I installed it on backs right up against my equipment rack room so I was able to run the charger cord thru the wall and plug it into an outlet on the other side. Very simple. I especially like this mount because the faceplate is removable by way of magnets (strong magnets at that). It comes off easily and the iPad pops right out. Wifi signal is not affected by the mount whatsoever. I still have to spackle and touch up a couple of holes from something that was hanging there before but here are a couple of shots of the new wall mount shortly after I finished:
Close up:
Face plate off:
Back of face plate:
If you are in the market for a nice, AFFORDABLE iPad wall mount, I highly recommend this product!!
Displays: Epson 5030UB | 100-inch Elite Sable Fixed Mount | Samsung UN46F5500 LED TV
Sources: Yamaha RX-A1010 | Emotiva XPA-3 | OPPO BDP-103 | Panamax M5300 | Pro-ject Carbon Debut Turntable | Sonos Connect | Apple TV
Speakers: Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk 65RT (L/R SUR) | Polk RC80i (L/R REAR SUR) | Subwoofers: PSA XV-15se X 2
Controls:Wall-mounted iPad AVS Forum Thread: 904WMC Media Room Thread
AnnapolisSony is offline
post #77 of 81 Old 11-19-2014, 09:51 AM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
Nice find! Looks great, thanks for the feedback & pics!
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #78 of 81 Old 11-20-2014, 03:41 PM
AV_Integrated's Avatar
Quoted: 972 Post(s)
Liked: 718
Woot! Redskins!
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #79 of 81 Old 11-06-2016, 02:27 PM
Quoted: 61 Post(s)
Liked: 5
what is the best, reasonable priced, on wall, iPad unit removable wall mount with electric connect. i have an iPad mini 4
Ziba Ji is offline
post #80 of 81 Old 11-22-2016, 08:23 AM
Liked: 0
I searched over the web and I found "Basalte" wall mounting system. I have sent them an email for pricing and I hope will be less than $100 for the ipad since I will need total 6 to install them to evry single room.
R3dBull is offline
post #81 of 81 Old 11-22-2016, 08:29 AM
Liked: 0
Forgot to mention that "Basalte" product is the EVE series and it has also for ipods & ipad mini. Also there is another product called "Design wall frame Apple ipod Touch 4 Generation" from Lingg-Janke. It seems that is cheaper than other in the market (from my search) and they have for ipad too (not sure if it is for latest ipad models).
R3dBull is offline
Reply Home Automation
