I know the iPad is a MOBILE device but I am really set on having something wall mounted and think this mY satisfy my needs for ac control mostly. I have been reading/researching on here about different touchscreen HA options e.g. Lutron, Homeseer, control 4 etc. But they are somewhat involved and expensive. Has anyone here us an IPad as I suggested? Are they mounts that can enabled the IPad to be removed? It needs to be charged/updated so I would need to run the wires to the iPad for this. All my walls are open now for the next few days.... Thanks.
Thanks guys. I would really like it to be recessed/flush mounted. Wonder if they make some sort of bracket like that. Can an iPad mini be used just the same? Most of the frames seem to be for iPad and not mini. Are there limitations, besides screen size, for the mini? It does have Wifi.
I use wall mount and mobile iPad's (with Savant home automation). Personally I think a hybrid option would be much better, like iPort's LaunchPort solutions. I am going to implement that as the best solution (with iPad mini's). Look it up ...
i want to mount my ipad recessed/flush on the wall(would really like a mount(not surface) that will enable me to "pop" the ipad out if I wanted to. I
m looking for ideas on where to run the usb to so I will have charging and updating capabilities. Just pop it out near an outlet? I know Vidabox has the Vcharger but I still need to mount the usb unit close to the ipad as I need to run the cable from the unit to the ipad so the USB can't be too long.
This looks good but what happens when I need to update my ipad if I can't readily remove it from the wall? If I run a usb a short length through the wall near a power outlet this will be ok but I'm not getting where the wire would end up near the outlet.....like I said before.....just hanging out? No......maybe a foot or two coiled in a box with a removable cover next to it.
That Vidabox vCharger allows the power to be extended over category cable - power cable converted from USB to category cable. IIRC, can extend to 60 feet. That blue cable running into the wall, in this pic, is a category cable.
I'm no apple expert, but I'm pretty sure you don't need to physically connect the iPad to a PC anymore for updates - wireless updates.
Originally Posted by Neurorad /t/1462031/ipad-as-wall-mount-touchscreen#post_23052737
Why do you need to connect the USB to your mac? You can use wireless sync and the iPad can install its own software updates. Unless you are worried about jailbreak it probably isn't necessary.
Originally Posted by Neurorad /t/1462031/ipad-as-wall-mount-touchscreen#post_23051105
Crestron's in-wall iPad dock is pretty sweet. We use a lot of them in high-end residences. Here's a picture of one if you want to see how it looks in a real project.
Agreed on Crestron's docks, they do look and work nicely. Travis, I like how you're using Crestron docks with a Savant system. Any reason you decided against Savant's own docks aside from the ability to easily remove the iPads?
Crestron dock looks very sweet. Want a iPad mini dock though(Crestron says its coming soon)....sh$@? I do have the iPad 1(lol I know...only use it for Internet)..... should/could I use that or is it too old thus might have limitations as a controller?
Yes, you can easily take the ipad out of the case, but there isn't really a point. It doesn't add that much bulk to it.
Their website says the mini sleeve is "coming soon" -- whatever that means. They also say the iPad 4 sleeve is "coming soon" and the iPad 4 has been out for a long while now -- likely they are having issues with the lightning port. So who knows how long it will take.
here's some pics of my kitchen install in-wall paid 200 for mount on amazon and i'm very please with end results!
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
