Harmony 1100 and Lutron RadioRA 2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-22-2013, 09:36 PM - Thread Starter
BRAISKI's Avatar
Quoted: 16 Post(s)
I have the Harmony 1100 and now planning to have a full Lutron RadioRA 2 setup in my living room. But it seems that you need to beat around the bushes to get the 1100 to work with RadioRA 2. Does anyone here have this set up?
Denon 2809CI
C: Def Tech - CLR2002
F: Def Tech - BP2002TL
S: Def Tech - BP1.2X
SB: Def Tech - PM400
Sub: Plan to get the SVS-SB1000
BRAISKI is offline
post #2 of 6 Old 03-23-2013, 05:16 AM
mystikjoe's Avatar
I replaced to logitech 1100s after switching to radiora2 and roomie remote! Made them seem like dinosaurs. I use iPads and iPhones for a much better user experience.
mystikjoe is offline
post #3 of 6 Old 03-23-2013, 05:35 AM - Thread Starter
BRAISKI's Avatar
Quoted: 16 Post(s)
Thats really too bad, it seems that Logitech didn't want to license the technology with Lutron. I don't use Apple products so I'm looking for other options. Maybe if Logitech will have the "1200" might be better.
Denon 2809CI
BRAISKI is offline
post #4 of 6 Old 03-23-2013, 08:07 AM
mystikjoe's Avatar
I've been a Logitech user for years. the 890 then the 1000 (zwave first attempt for light control for me) then 2 1100's. I feel like they are greatly overpriced for what you get. pick up a used ipad mini for 250-300 vs 300 for and 1100? that's without the rf repeater which will set you back another 100. I really feel like i'm set back 10 years when using the 1100 vs the ipad after using it for years and about 3 months with roomie remote on my ipad.
post #5 of 6 Old 04-12-2013, 06:31 AM
dctheaters's Avatar
So which would you guys say is the better app for the lighting control and everything else? Roomie remote, RTI Panel, or the Lutron app?
www.dchtheaters.com
"Electronics should be simple; on, off, up, and down."
dctheaters is offline
post #6 of 6 Old 04-12-2013, 09:19 AM
mystikjoe's Avatar
i personally use both the roomie and the lutron app. as far as integration with the lutron app i have control of my lights, hvac, and garge doors. i have the radiora2 setup integrated in my roomie commands. if i launch watch directv i made custom buttons to turn lights on and off and dim them from the onscreen directv remote. i have no experience with the rti but i can say i'm very satisified with the roomie software and the lutron.
Reply Home Automation
Harmony 1100 Remcontrol
