Electrical Boxes / Gang Back Box - AVS Forum | Home Theater Discussions And Reviews
Old 04-03-2013, 07:01 AM - Thread Starter
pezzeonline's Avatar
Hi, I'm from Italy.
Our company is developing a new home automation project. We have done the first prototype for Italy electrical boxes but we want to expand our business in USA.
Can someone tell me if there is an USA standard for electrical boxes? For example in Italy the standard is 503 boxes (like this: http://it.rs-online.com/web/p/scatole-da-incasso/2700730/).
I found different boxes but all with different dimension, for example in this site: http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=42101&minisite=10251 and I don't understand which is the most used in houses.
pezzeonline is offline
Old 04-03-2013, 08:23 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
This is the typical switch / outlet box for the US. Depending on regional code and commercial or residential use, these may be metal boxes or plastic. I don't know if there's a standard or minimum requirement for the depth of the box - which is probably what you really need anyway.
http://www-public.tnb.com/ps/fulltilt/index.cgi?part=B118A
Hope that helps, there's some electricians on the forum that can hopefully give you more information.
Jeff
jautor is offline
Old 04-04-2013, 12:29 PM
Colm's Avatar
Liked: 94
You need to buy the ANSI OS1 and OS2 standards. You can get them here.
The 18 cubic inch nonmetallic box Jeff mentioned is probably typical of what is used in most new construction for a single switch or receptacle. A 14 cubic inch nometallic old work box is probably most common for upgrades. The main difference between the two is the internal height is less in the old work box. Although these two are probably the most common, they are a lot of other variations. Some boxes intended for tight spaces have a depth of only 1". You may want to take a look at more manufacturers' catalogs to get an idea of the variations. Some of the major brands are Carlon (non-metallic) and Raco (metallic), and Red Dot for exterior boxes.
Pay close attention to the horizontal spacing between mounting holes for gang boxes (2 or more switches). It is less than the width of a single switch box. IOW if you make the width of your devices the same as the width of a single switch box, they may not fit in gang boxes.
The actual use of the boxes is governed by the local electrical code. The code varies from state to state, and sometimes within states. But it is almost always based on some version of NFPA 70, the National Electrical Code (NEC). The number of current carrying wires coming into the box will affect the minimum size permitted. You can get a copy of the current version of the NEC from the NFPA.
You may want to look at the dimensions of competing products for the US market as well.
Are you familiar with the other aspects of producing a product for the US market, including certification by a NRTL like UL or ETL?
Colm is offline
