Projector without 12V trigger, how do I get one? - AVS Forum
post #1 of 5 Old 04-07-2013, 03:42 PM - Thread Starter
RikkyNO's Avatar
I just replaced my projector with a new one without a 12V trigger, which i need to control my screen. Is there a device out there that can act as a 12V trigger when i turn on my projector? Like those things that you connect to the power cable (230V in my case) and senses when you turn on the projector, are those available with a 12V trigger anywhere?
RikkyNO is offline
post #2 of 5 Old 04-09-2013, 06:24 AM - Thread Starter
RikkyNO's Avatar
Anyone? Or isn't this possible?
RikkyNO is offline
post #3 of 5 Old 04-09-2013, 09:38 AM
DMILANI's Avatar
DMILANI is offline
post #4 of 5 Old 04-09-2013, 09:45 AM
DMILANI's Avatar
I just saw you need 220V. Sorry, I'm not sure then.
DMILANI is offline
post #5 of 5 Old 04-09-2013, 09:51 AM
DMILANI's Avatar
OK, this should work and should be less than $100.00 if you shop around online.
You will need this:
http://www.xantech.com/controls/controllersswitches/ControllersSwitchers/SMMAG01/
And this:
http://www.xantech.com/controls/controllersswitches/controllersswitchers/CBCSM1/
And the following with the correct adapter for your region:
http://www.xantech.com/Infrared/Infrared/PowerSupplies/781ERGPS/
That should do it. The SMMAG01 has a sensitivity adjustment for idle current. I actuall use one of these to check that my PS3 is either on or off and works great.
Hope this helps.
DMILANI is offline
Reply Home Automation
User Tag List
