Help: Control4 HC-200 setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-07-2013, 06:20 PM - Thread Starter
gdfein's Avatar
Quoted: 17 Post(s)
Looking for guidance. I've recently purchased a new home in the North Houston area that is approx a year old and the prior owner included a small HC-200 system that the builder included. The system in includes the controller and 3 light switches. The system was never used before from what I am told and the equipment appeared to be new in box.
I connected the HC-200 controller to my TV using component video out and stereo audio out to one of the component inputs on the tv. I also ran Ethernet between controller and a switch connected to the house network. The switches functioning as other devices on it are fine.
When I power the controller up and change to the proper tv input, I get no signal at all. The controller has no means to change input and I have no remote for it.
I was expecting to be able to register and license the controller using my ipad.
But I am at an impasse.
Please help
Greg
gdfein is offline
post #2 of 3 Old 04-08-2013, 05:57 AM
Dawn Gordon's Avatar
Quoted: 157 Post(s)
Liked: 112
Greg,
You need a Control4 dealer to properly set up the system. Go to the Control4 website to locate a local dealer who can help you.
Dawn Gordon is offline
post #3 of 3 Old 04-08-2013, 06:08 PM
bluewaves's Avatar
Find a local C4 Dealer https://www.control4.com/dealer-locator
Your C4 system needs to be programmed and you will need to purchase a license for the iPad.
bluewaves is offline
Reply Home Automation
