iPad/Tablet Wall Mounting Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 05-06-2013, 02:32 PM - Thread Starter
akevit's Avatar
I'd like to compile information for use so that I can hopefully find a better product than what I have. My ultimate goal would be to flush mount my iPad in the wall with a power source and be able to pop the iPad out if wanted, though the solutions that do that are a few hundred dollars. So what I'm going to do is start a list with the item name, website, USD purchase price, and a picture. If you have any other info to contribute let me know.
Threads/Links
iPad as wall mount touchscreen
Cocoon Tech Website
DIY Link
iPad Mounts
  1. Channel Vision On-Wall Docking Station - $165
  2. LOXONE iPad Mount - $40 (ships from Europe)
  3. Vidabox - Various (no iPad 1) - $100
  4. ProClip Wall Mount Holder (There are other mounts from ProClip too - $50
  5. Wallee / Studio Proper Wall Mount System - $50 (includes cost of the wall mount disc)
  6. iPort - Control Mount - $595 (Couldn't find a good link on their website so listing Best Buy retail)
  7. Crestron in-wall iPad Dock - Not really sure on price or where to get, this one lists it at $370
  8. Savant In-Wall Dock - $$$???
  9. iRoom iDock Alu Portrait - No idea on price
  10. Trufig - Again not sure on price
  11. Koala iPad Mount - $20
  12. iPort LaunchPort System - ($350)
Universal Tablet Mounts
ProClips Makes some
Wallee Makes some
Koala Above is universal
"Kiosk" Mode
So I wanted to also make the device somewhat user friendly and in a way "secure" so that if I have people over the "Remote" application will always be there and so someone might not accidentally screw something up. To do this you have to jailbreak your iPad then install the following:
  1. NoLockScreen - Disables the lockscreen entirely so that the device can be brought back from sleep with just the home button and you don't need to swipe to unlock the screen
  2. AppLocker - Allows you to enable a password for any application. Essentially for this iPad, I enabled AppLocker on every app but Remote, Safari, & Weather
  3. IncarcerApp - Allows you to set a hot key so that you can "lock" an app, further, once an app is locked, you can disable the sleep button and the home screen button. This way someone can't power cycle the device or get out of the app. To get out of the app, you just double-tap a special area of the screen.
akevit is offline
post #2 of 18 Old 05-06-2013, 05:26 PM
az1324's Avatar
Quoted: 24 Post(s)
iPort looks the best and is available for $300. But I would be tempted to DIY with one of the clip mounts and a custom faceplate out of laser cut material. Not sure what I would do for the backer box though.
az1324 is offline
post #3 of 18 Old 05-06-2013, 05:55 PM - Thread Starter
akevit's Avatar
I was discussing with a friend some possibilities for this, it seems like it would be completely feasible to get a bracket in the wall then fix a case to the bracket for the iPad. I haven't come across any that have been done and haven't done much research on cases that are out there. I'm just starting with the Koala one since it's cheap and simple to install. I couldn't decide on anything else and just wanted to get it up there with something. I'm pretty sure I can cover the blue backing with another color.
akevit is offline
post #4 of 18 Old 05-07-2013, 04:49 PM
Travisleo's Avatar
The two best that we have used are the Launchport and the Crestron in-wall dock (the picture in the original post is actually from one of our installations). While they are expensive, you get what you pay for.
Travis Leo
Denver, CO
Residential Systems, Inc.
www.ResidentialSystemsInc.com
Travisleo is offline
post #5 of 18 Old 05-08-2013, 04:49 AM
greenbone's Avatar
ive got the loxone mount
pros:
- simple to install
- easy on and off
- clean look / thinnest bezel option / unobtrusive
- cheap
cons:
- if you knocked it hard the ipad would fall out and onto the floor
greenbone is offline
post #6 of 18 Old 05-08-2013, 08:03 PM
AV_Integrated's Avatar
Quoted: 971 Post(s)
Liked: 718
The iPort products are awesome, but if I were going for near flush with removable, then I would go with this:
http://www.launchport.com/
The Launchport is actually an iPort product, but I absolutely love the inductive charging and the complete on/off ease of use. You can put up a wall charging unit and put your iPad into a sleeve and then just slap it up on your wall. Rotate it portrait or landscape as you choose. The magnet is the right amount of strong without making it impossible to remove the iPad from the wall station.
Yes, it does protrude, but it is well under an inch and is more like a photo on the wall. I'm sure that there are ways to customize this to get it more 'flush', but it may make it difficult to take off the wall.
Just my $.02 on things.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #7 of 18 Old 05-13-2013, 01:10 PM - Thread Starter
akevit's Avatar
Hmm Launchport looks nice but yeah a little spendy, also there is no case for the iPad 1G it looks like.
Here's the Koala Mount:
akevit is offline
post #8 of 18 Old 05-21-2013, 10:56 AM
Quoted: 971 Post(s)
Liked: 718
Yeah, no iPad1 version for LaunchPort, and I wouldn't hold my breath for one. But, the inductive charging is really nice and the fact that it is upgradable as your iPad changes to new products is really cool. Potentially, they could make sleeves for it in the future which would work with a Samsung tablet or other products is also a really cool thing. I've hands-on tested one and it is by far my favorite as being a professional 'high-end' product. But, I don't own one. WHY? Yep! It's pricey! smile.gif
post #9 of 18 Old 05-21-2013, 02:53 PM
gadgetfreaky's Avatar
Quoted: 21 Post(s)
Yeah I just called them, no ipad 1. And so far, no Nexus 7 Android. I guess a used iPad2 for $300 and this kit which you can find both pieces for around $325 make for a $625 wallmounted touch screen.
I was going to try this for the living room, a place to charge the ipad, but as you walk in you can grab it, sit down and use it as the remote. Whether Control4 or iRUle this would be pretty good as a remote to control shades, lighting, and TV etc.
Even as a place for the kids to be able to charge their iPads.
gadgetfreaky is offline
post #10 of 18 Old 09-28-2013, 08:14 AM
ScAndal's Avatar
Liked: 27
Great thread. Time to research for my build. Thanks for the head start
ScAndal is offline
post #11 of 18 Old 09-28-2013, 08:27 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Basalte 'Eve'
Europe only, currently.
pdf brochure: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&ved=0CDAQFjAB&url=http%3A%2F%2Fwww.basalte.be%2Fdata%2Fpdf%2Feve_brochure.pdf&ei=OehGUr-3Fa_YyQGIsoDACQ&usg=AFQjCNFrqk0NhQPw8XTmzgtCGmYodW8AKA&sig2=hSu-SleNcwfSsya_yiBnMA
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #12 of 18 Old 09-28-2013, 08:29 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Smart-Things sDock
From Europe.
http://www.smart-things.com/en/sdock-pro.html
Neurorad is offline
post #13 of 18 Old 09-28-2013, 12:39 PM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
pros:
- simple to install
- easy on and off
- cheap
cons:
I hate imagining the ipad falling. My #1 ipad rule (and only rule generally) is don't drop it.
Brian Hampton is offline
post #14 of 18 Old 10-01-2013, 07:43 PM
Shady_'s Avatar
If anyone is looking for a DIY solution for an Android tablet, see mine here with inductive charging and very minimal equipment on the wall:
http://www.controlmypad.com/projects.html
It also holds my iPad2 (see bottom of page in above link), but only as a holder (Apple hasn't caught on to joys of the inductive charging yet) since I added a strip of steel internally for the magnets to grab onto.
I may have been able to shave off the "ledge" as some have asked me, allowing only magnets to hold the tablet, but the "ledge" marks where the tablet goes and provided that extra bit of support so I never have to worry about it dropping.
Shady_ is offline
post #15 of 18 Old 10-02-2013, 11:56 AM
ScAndal's Avatar
Liked: 27
Love it! Nice work and thanks for sharing.
ScAndal is offline
post #16 of 18 Old 11-19-2014, 08:17 AM
AnnapolisSony's Avatar
Quoted: 93 Post(s)
Liked: 136
Ever since I completed my room, I’ve been using an iPad to control things like my Sonos, my OPPO and my Yamaha AVR. My iPad was in a protective case and would either sit up on the bar top or the on the chairs. For the longest time I’ve wanted to mount it in the wall and recently I decided to finally tackle it. Honestly, I was blown away at the prices of some of the iPad wall mounts out there. Some of them even topped $300-$400 (iPort, etc.) which I knew right off the bat I was NOT going to pay.
After going back and forth and back and forth I decided to take a leap and purchase a $99 mount from a guy on eBay. I later found he sells his mount on a website at:
http://www.simplewallmount.com
I needed two things in a wall mount: 1) An attractive looking, easily-removable flush mount with home button exposed 2) Option to hook up a charger/power cable.
This product delivered both and for a fraction of the cost of most others on the market. It actually comes with two face plates so you have a couple of different looks if desired.
I installed it last night and it was a piece of cake. The wall that I installed it on backs right up against my equipment rack room so I was able to run the charger cord thru the wall and plug it into an outlet on the other side. Very simple. I especially like this mount because the faceplate is removable by way of magnets (strong magnets at that). It comes off easily and the iPad pops right out. Wifi signal is not affected by the mount whatsoever. I still have to spackle and touch up a couple of holes from something that was hanging there before but here are a couple of shots of the new wall mount shortly after I finished:
Close up:
Face plate off:
Back of face plate:
If you are in the market for a nice, AFFORDABLE iPad wall mount, I highly recommend this product!!
Displays: Epson 5030UB | 100-inch Elite Sable Fixed Mount | Samsung UN46F5500 LED TV
Sources: Yamaha RX-A1010 | Emotiva XPA-3 | OPPO BDP-103 | Panamax M5300 | Pro-ject Carbon Debut Turntable | Sonos Connect | Apple TV
Speakers: Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk 65RT (L/R SUR) | Polk RC80i (L/R REAR SUR) | Subwoofers: PSA XV-15se X 2
Controls:Wall-mounted iPad AVS Forum Thread: 904WMC Media Room Thread
AnnapolisSony is offline
post #17 of 18 Old 05-16-2016, 09:34 AM
dudesky's Avatar
Liked: 0
A very cost effective ipad and universal tablet wall mount can be found at thepadtab.com Their system works great and it doesn't break the bank!
dudesky is offline
post #18 of 18 Old 05-16-2016, 12:39 PM
ozzman_8's Avatar
Close up:
Face plate off:
Back of face plate:
Love the setup and great wall mount.. HTTR...
ozzman_8 is offline
Reply Home Automation
