Advise needed for A/V control & Automation - AVS Forum | Home Theater Discussions And Reviews
Old 05-17-2013, 11:00 PM - Thread Starter
keyxote's Avatar
I need an All-in-one solution for a universal remote system to control my A/V system, some lighting, irrigation system, and security cameras. I have a small 1500 sq ft home with decent wifi network coverage.
I've used several versions of Logitechs harmony remotes, with the most recent being the Harmony touch and 1100. So far I've been less than impressed except for the fact that I was able to get down to one remote. I have some Lutron light switches with IR receivers. I have the NEST thermostat controller. I am looking for a networkable irrigation timer to replace my current system.
I like the Control4 system that was demo'd at Best Buy's Magnolia Home showroom but I wanted to see what other options I have. Any suggestions?
keyxote is offline
Old 05-18-2013, 08:43 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
We use Control4 and love it.
HC-1000
2 HC-300C
1 HC-200
1 HC-200B
5 SR-250
Front door lock
Garage door control
My Home site license for iPads and iPhones.
If you go with C4 make sure you find a good dealer...
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is online now
Old 05-18-2013, 11:00 AM
force10's Avatar
Quoted: 16 Post(s)
RTI for me, it comes down to good installer and programmer and support.
force10 is offline
Old 05-19-2013, 12:43 PM
roddymcg's Avatar
The above goes for all control systems...
roddymcg is offline
Old 05-23-2013, 03:37 PM
mdk319's Avatar
HC-1000
2 HC-300C
1 HC-200
1 HC-200B
5 SR-250
Front door lock
Garage door control
Would the equivalent RTI system by similar in price? From what I understand RTI is a little less expensive?.?
mdk319 is offline
Old 05-24-2013, 03:06 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
I don't know anything about RTI. Sorry.
Control4
Old 05-27-2013, 11:49 PM
roddymcg's Avatar
I believe RTI is generally a little more expensive than Control4. RTI is a bit more flexible than Control4. Either way, make sure if you are hiring this out you are comfortable with the integrator.
roddymcg is offline
Old 05-28-2013, 07:25 PM
scottacus's Avatar
Based on your description of your needs, you may also want to look at Roomie Remote and iRule. Depending on your components they may be able to meet your needs and are far cheaper than Control4 or RTI. Roomie is DIY and iRule is either DIY or pro installed.
scottacus is offline
Old 05-28-2013, 08:11 PM
themoderntheatre's Avatar
I just became a Control4 dealer and I have to say I'm pretty impressed by it especially with the price points. I was comparing a friend's URC MX-980 today and cost wise a Control4 HC250 and SR250 remote is cheaper comparing with URC + the MRX basestation. It's really a great starter to grow your system around.
Ryan Siu
Founder, Owner
The Modern Theatre LLC
themoderntheatre is offline
Old 06-10-2013, 12:00 PM
raczcar's Avatar
I would say go Control 4 Just make sure you have a good integrator. It is also nice because you can start with a simple controlled av system and then build on that.
raczcar is offline
Old 06-15-2013, 02:34 AM
gerard143's Avatar
Quoted: 12 Post(s)
Rti
gerard143 is offline
gerard143's Avatar
Quoted: 12 Post(s)
Rti
