Speaker control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-21-2013, 07:24 AM - Thread Starter
peterf1972's Avatar
Hello!
I recently installed 6 ceiling speakers (two more to come on the back-porch) and am currently powering them through a simple mini stereo with CD changer and aux input (connected to a computer). I can switch speakers in each room on and off via a manual speaker switch.
I would like to upgrade to have the following ability:
- control rooms separately via Android/iPhone devices and web interface
- have the choice of 2 or three audio sources, and two rooms can have different audio sources at the same time
What would be a device or solution i should start looking into? Is any of the Control4 devices able to accomplish this?
peterf1972 is offline
post #2 of 4 Old 07-21-2013, 08:32 AM
jautor's Avatar
Quoted: 1227 Post(s)
Liked: 787
You'll find lots of info in the Home A/V Distribution forum, one up from here.
A set of Sonos Connect:Amp units, or a NuVo P3100 (plus a P200 for the outdoor zone) would be a good solution...
peterf1972 likes this.
jautor is offline
post #3 of 4 Old 07-21-2013, 03:52 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
Originally Posted by peterf1972 View Post
Hello!
We use Control 4 to control our 11 zones of music. Rhaposdy and Tunein can be played in all zones. We started with one controller that controlled main living and back deck. You can start small then add on.
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is online now
post #4 of 4 Old 07-27-2013, 06:35 PM
AV_Integrated's Avatar
Quoted: 1007 Post(s)
Liked: 733
http://www.htd.com has some distributed audio systems with iPhone control which run under $1,000 for the entire setup.
Worth a look for sure for the average home. Always nice to have keypads if you can install them!
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Reply Home Automation
