Please help X10 having too much problem with signal noise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-29-2013, 10:18 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
I have the X10 light module XPS3-IW (WS13A)
It controls my LED "shop lighting" that I have in my HT room. My light is a terminal wire (not sure of exact name, but point is the electric wires end at the switch)
I also have the X10 home control software, and a x10 handheld remote to turn the lights on/off.
The one problem that I have is that VERY often the lights will shut off on their own. I checked the s/w and it indicates noise on the line, and called X10 and their tech's said that's the cause.
Another issue is that often times I need to press the remote many times until the light will turn back on, even if I'm standing close to the actual module (I've tried changing batteries on the remote)
I imagine having an electrician "fix the noise" or buying a line filter would be expensive. Is there a different product which is also inexpensive which is less sensitive to the line noise and won't shut off on it's own?
thanks
cgott42 is offline
post #2 of 4 Old 07-29-2013, 12:27 PM
MrGreeno's Avatar
I've not tried installing a noise filter though they are available.
Do you have a phase coupler installed?
I had a terrible time with noise and a weak signal in my first house..
I installed a coupler/repeater and now it works great.
If you're not familiar with it, what it does is couple the two phases together via a capacitor that allows the X10 signal to pass from one phase to the other without having to travel out to the transformer.
Mine is like the one linked below but the one I own has an active repeater circuit that relays the signal from one phase to the other.
http://www.ebay.com/itm/X10-Smarthome-SignaLinc-4816-Phase-Coupler-/221260568092?pt=LH_DefaultDomain_0&hash=item338428561c
A toast to Bill Brasky!
MrGreeno is offline
post #3 of 4 Old 07-29-2013, 12:59 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
Spoke with someone who mentioned getting Z-Wave devices - he explained that they are not affected by line noise as they don't send their on/off signals via the electric line, but rather via RF....
anyone know what module I'd need - i.e. what would be the Z-Wave counterpart to the X-10 WS13A?
Also - not a deal breaker, but is Z-Wave compatible with Harmony remotes?
cgott42 is offline
post #4 of 4 Old 07-29-2013, 03:56 PM
az1324's Avatar
Quoted: 24 Post(s)
az1324 is offline
Reply Home Automation
