retrofitting plantation shudders with motorized wifi control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-31-2013, 08:57 PM - Thread Starter
astro2013's Avatar
Quoted: 12 Post(s)
We have many windows in our new house with 2" plantation shudders. Are there any products that I can install that would allow for control of just the shades (not up/down).
astro2013 is offline
post #2 of 7 Old 08-31-2013, 09:52 PM
az1324's Avatar
Quoted: 24 Post(s)
I thought we got rid of plantation shudders when we ended slavery. (terrible "joke")
Some info in here: http://cocoontech.com/forums/topic/4210-automating-plantation-shutters/
Problem is you will have to find space for motors & battery pack or wiring without compromising appearance. Which probably means some woodworking.
az1324 is offline
post #3 of 7 Old 08-31-2013, 09:54 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You have shutters, and shades? Not up/down, but open/close?
Tilt open/close?
I don't understand.
Many shade/blind stores will offer control of plantation shutters. Ask around.
If you want a high end solution, call some local custom installation companies.
If you want really high end, have your assistant PM me.
Last time I checked, there wasn't a good retrofit solution. You would need to buy new motorized 2" shutters. For a single room, that may be an option.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 7 Old 09-02-2013, 08:41 PM - Thread Starter
astro2013's Avatar
Quoted: 12 Post(s)
I don't have actually plantation shutters... the builder called them 2 inch faux plantation shutters, so that's what we have always called them. They are just like this picture. Does that make the solution easier?
2 inch shutters.jpg 54k .jpg file
Name:	2 inch shutters.jpg
post #5 of 7 Old 09-02-2013, 11:10 PM
az1324's Avatar
Quoted: 24 Post(s)
Yes those are just faux wood blinds meaning they have a headrail and tilt mechanism that can be motorized relatively easily with something like a Somfy Tilt Motor kit.
Builder probably wanted to call them shutters because shutters are a more premium item.
az1324 is offline
post #6 of 7 Old 09-03-2013, 04:58 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
A local shade guy could add motors to those, yes, but not plantation shutters.
Neurorad is offline
post #7 of 7 Old 09-03-2013, 10:34 AM
David Haddad's Avatar
I'm intrigued by motorized wifi control. So the motors are driven by wifi? Or the wifi is motorized? biggrin.gif
David Haddad is offline
Reply Home Automation
