Free Lutron RadioRa2 iPhone App - AVS Forum | Home Theater Discussions And Reviews
Old 09-01-2013, 06:54 PM - Thread Starter
srmadden's Avatar
I've just released a free iPhone app to control Lutron RadioRa2 networks. It's designed to be super simple to install and use, and to work via the telnet interface (so doesn't require a professionally installed network / activated repeater).
It's called Lutron Light Control:
https://itunes.apple.com/us/app/lutron-light-control/id683647959?mt=8
I've only tested it on a basic network with a few light switches, so I'd especially love feedback about whether it works with other types of devices. If others are interested in helping develop it, I'd be happy to release the source code as well.
I'd love to hear any comments / feedback if anyone is interested in trying it out.
srmadden is offline
Old 09-01-2013, 10:15 PM
az1324's Avatar
Quoted: 24 Post(s)
So does it work for systems that were set up without the (RA2) software?
az1324 is offline
Old 09-02-2013, 05:57 AM - Thread Starter
srmadden's Avatar
Yes.
It does not all you to access some features, such as timed events. In addition it can only emulate a button on a switch or remote, so to control multiple lights with a single button in the app, you must have a remote button programmed to do that.
srmadden is offline
Old 09-02-2013, 06:52 PM
cmcjo's Avatar
I installed it but shouldn't it automatically load rooms and dimmers and keypads from my controller? It seems like I have to manually create everything?
JOE
cmcjo is offline
Old 09-02-2013, 06:55 PM - Thread Starter
srmadden's Avatar
This app uses the "telnet" interface, so can't access pre-programmed rooms / dimmers / keypads -- so yes, you have to manually enter everything. (I realize that this may seem like a significant drawback, but by using this more limited interface this allows the app to work with systems that have not been programmed.)
srmadden is offline
Old 09-02-2013, 07:02 PM
az1324's Avatar
Quoted: 24 Post(s)
Originally Posted by srmadden View Post
Yes.
Well that's still useful.
az1324 is offline
