Help...Is there a product that can dim several recessed lights in a series but not all lights - AVS Forum | Home Theater Discussions And Reviews
Old 09-01-2013, 10:02 PM - Thread Starter
mmgolf5's Avatar
I have 13 LED recessed lights on a 4-way switch in a new finished basement. One of the three light switches is a dimmable switch. Part of the basement includes an open media room and I am hoping to break up the run of lights by being able to dim four of them when watching a movie (due to reflections) but leave others on. Are there any products available that can be attached to the recessed light housing to control an individual light?
mmgolf5 is offline
Old 09-01-2013, 10:26 PM
az1324's Avatar
Quoted: 24 Post(s)
Yes Insteon micro modules, Aeon Labs makes something similar for z-wave.
But you will have to think about how you are going to wire it because you want constant power (not switched/dimmed power) to those modules and you don't want a dimmer behind a dimmer. So the existing wiring is going to limit you.
The best solution may be to replace all 3 switches with Insteon switchlinc or equivalent and add 2 micro modules (1 for each group).
Otherwise you can consider smart bulbs such as philips hue, insteon LED bulb, LIFX which can be controlled by smartphone/tablet. But they do not have the best brightness. You would also need to remove the dimmer in front of them.
az1324 is offline
