Problem mounting camera over single gang box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-03-2013, 09:41 PM - Thread Starter
killswitch1968's Avatar
I bought a Vivotek camera - FD8151V for outdoor use. It's to be mounted outside but the Cat5e wire is comes out of a gang box. The camera is not meant to be mounted over a gang box just over a small hole where the wire comes out, so it doesn't fit properly and leaves gaps (picture of wire below).
What are my options here? Do I just put a plate over it and mount it on that? Is there a 3rd party mount that would work? The manufacturer offered no solution.
killswitch1968 is offline
post #2 of 3 Old 09-04-2013, 07:57 PM
bravonoj's Avatar
I would return the camera and get a bullet style camera to mount over a plain wallplate. Or mount that dome camera on the wallplate, either way would be ok but I cant be positive without seeing the camera.
bravonoj is offline
post #3 of 3 Old 09-05-2013, 09:14 AM
M1chael's Avatar
Quoted: 12 Post(s)
M1chael is offline
Reply Home Automation
