elan g - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-06-2013, 07:19 AM - Thread Starter
harry123456's Avatar
Ive got a elan g controller but having trouble programming a hc4 I cant get the right codes for my sky box and which template do you use? Spent a lot of money with a company but they dont want to help, be gratefull any advise thanks.
harry123456 is offline
post #2 of 3 Old 10-08-2013, 08:48 AM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
What is a "Sky Box"?
Assuming this device uses IR and it doesn't exist in the Elan database you can purchase the IR learner (which works very well) and learn the needed codes from the existing remote.
Or if you can find the IR codes in CCF format you can paste them into a IR device of your own creation.
I used the existing templates to get ideas about how Elan thought things should be done but in the end I designed my own.
Regards, Frederick C. Wilt
fcwilt is offline
post #3 of 3 Old 10-08-2013, 09:52 AM
AV_Integrated's Avatar
Quoted: 1013 Post(s)
Liked: 734
I believe Sky is the UK version of DirecTV. I've heard it mentioned a ton, but never bothered to Google it.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Reply Home Automation
