ZWave USB stick compatible with Windows 8 x64? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-15-2013, 10:48 AM - Thread Starter
crbaldwin's Avatar
Quoted: 80 Post(s)
Liked: 25
I have one of the original Intermatic HA22 ZWave USB sticks but was never able to get it to work with Windows 7 x64 (never found appropriate drivers). I have been looking at the Aeotec Z-Stick but there seems to be no indication what OS it is compatible with. Does anyone know if it will work with Windows 8 x64 or have another recommendation (would like to keep it under $100). Thanks.
crbaldwin is offline
post #2 of 3 Old 10-17-2013, 07:36 AM
replayrob's Avatar
Quoted: 874 Post(s)
Liked: 895
Have you seen the "Aeon DSA02203-ZWUS Labs Z-Wave Z-Stick Series 2 USB Dongle" ?
http://www.amazon.com/Aeon-DSA02203-ZWUS-Labs-Z-Wave-Z-Stick/dp/B003MWQ30E/ref=pd_cp_e_3
If you look at the Questions section... ppl have been using it with Win7, don't know about x64 though. You could probably run it in a "Windows XP Mode" virtual PC that's free for WIn7 users. I've done that for USB hardware that doesn't have x64 drivers for Win7.
Everybody has a plan until they get punched in the mouth!”
M. Tyson
replayrob is offline
post #3 of 3 Old 10-17-2013, 10:58 AM - Thread Starter
crbaldwin's Avatar
Quoted: 80 Post(s)
Liked: 25
Thanks, that's the same one I've been looking at. I guess I will just contact the manufacturer to make sure.
Reply Home Automation
