Anyone know an automation (Control4) tech in Orlando area? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-16-2013, 05:09 AM - Thread Starter
and3331's Avatar
Hello, I am looking for an automation tech (experienced in Control4) who can provide on-going support/maintanance to my rental home in Kissimmee area. Is a 5 bed home with dedicated movie room, games room, family room system, Rhapsody music service etc. The automation is based on Control4 system (with a number of 7" wall panels, AC thermostats, Control4 light switches, Control4 remotes, ceiling speakers in various parts of the house etc).
Tech needs to be local to Kissimmee and can provide reasonably priced support within 24 hrs. The house is used for short term rentals so occasionally things dont work as they should and is important to have prompt support.
If anyone has recommendations, I would appreciate it! Many thanks.
and3331 is offline
post #2 of 6 Old 10-16-2013, 10:44 AM
cdika17's Avatar
Did you try using the dealer search on the website?
Millennium Waves
Contact Info
5369 Los Palma Vista Drive
Orlando FL 32837 407-448-5812
www.millenniumwaves.com Authorized Control4 Dealer
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #3 of 6 Old 10-30-2013, 08:10 PM
Vincent941's Avatar
Try bestbuys geeksquad They are a control4 authorized dealer.
Vincent941 is offline
post #4 of 6 Old 10-30-2013, 08:37 PM
Oybub1952's Avatar
I'm in Kissimmee and I have a tech guy but it takes days to get him to my place..But i haven't had anything that was urgent.. I'll text him tomorrow and see if he is interested. There is a guy in St Cloud also .. I'll see if I can find him. Does it on the side. Works for an installer in Orlando..I found both of them are the web.
Oybub1952 is offline
post #5 of 6 Old 11-01-2013, 08:06 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
I wouldn't recommend that.... All of the Geek Squad's work that I've had to come in behind (read: "fix") is subpar at best. Also I'm fairly certain their programmers don't get sufficient C4 training.
cshepard is offline
post #6 of 6 Old 11-01-2013, 10:23 PM
David Haddad's Avatar
Funniest AVS post of the year tongue.gifbiggrin.gif. While he's there maybe he can ask them to refill his plasma with gas (old joke some will get, some won't).
David Haddad is offline
Reply Home Automation
