Off-The-Shelf home automation with DIY options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-05-2013, 07:30 AM - Thread Starter
borisw37's Avatar
Just starting out with home automation.
Can somebody recommend a system that has both off-the-shelf components and also provides DIY support (API, communication protocol, etc...)
Basically I don't want to re-invent the wheel and build the entire system from ground up, but I would like to be able to create my own controllable devices. I'm a ME/EE engineer with knowledge of embedded firmware so designing a PCB, implementing zigbee, etc.. doesn't scare me.
Thank you,
Boris.
borisw37 is offline
post #2 of 6 Old 11-05-2013, 10:08 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You might want to consider CQC - Charmed Quark Controller
http://www.charmedquark.com/vb_forum/index.php
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 6 Old 11-05-2013, 10:43 AM
az1324's Avatar
Quoted: 24 Post(s)
Insteon w/ ISY
Z-Wave w/ Vera
Zigbee w/ Smartenit ZBPServer
Pytomation
Premise
XAP
SmartThings
az1324 is offline
post #4 of 6 Old 11-05-2013, 11:45 AM - Thread Starter
borisw37's Avatar
Thank you for the info.
Let me clarify: My concern was mostly about hardware comparability.
If, for example, I get a Vera hub, will I be able to build my own sensors / actuators as opposed to just using off-the-shelf modules?
Is the communication protocol between Vera and its devices open source ?
borisw37 is offline
post #5 of 6 Old 11-05-2013, 12:19 PM
az1324's Avatar
Quoted: 24 Post(s)
If it is off-the-shelf in this category, chances are it is proprietary. So you should expect to run multiple networks (open and proprietary) side by side and use Vera or Raspberry Pi or other device you can run your own code on to bridge these networks.
az1324 is offline
post #6 of 6 Old 11-06-2013, 06:32 PM
Shady_'s Avatar
Yes you can build your own sensors/actuators. Vera software/firmware itself is proprietary but its interaction with devices is open, employing UPNP, http, Serial, etc. Z-Wave isn't open source except for Open Z-Wave which you might also look at. https://code.google.com/p/open-zwave/
Also @az1324 suggestions are a good way to add Arduino's, repurposed Pogo Plugs, or other I/O board options.
Shady_ is offline
Reply Home Automation
