Zwave thermostats for dummies - AVS Forum | Home Theater Discussions And Reviews
Old 11-09-2013, 06:40 PM - Thread Starter
pboulay's Avatar
Hello all!
Before I buy zwave controler and stuff, I want to understand what is the possibility with the zwave technology thermostats................
There is a lot of expensive thermostats that you can program the degrees for each day of the week but I have a thermostat in every room so it's expensive to switch  on zwave technology.
My question, is it possible to have a cheap zwave thermostat(with only + and - button) that you can program with the zwave controler using an Android device for example? Or we absolutely need an expensive thermostat with programming options?
What I want to do is to have cheap controller in each room and go on an app in my phone to program each room to change the temperature depending the time of the day. Is it possible?
Or if someone can suggest me an other solution, you are welcome! :)
Pat
pboulay is offline
Old 11-09-2013, 09:52 PM
az1324's Avatar
Quoted: 24 Post(s)
You have a thermostat in every room? That sounds like a zoned system. You usually can't replace equipment in zoned systems with off the shelf single zone stuff.
az1324 is offline
Old 11-11-2013, 03:26 PM - Thread Starter
pboulay's Avatar
So there is no zwave solution for people like me with a thermostat in each room?
pboulay is offline
Old 11-11-2013, 10:39 PM
az1324's Avatar
Quoted: 24 Post(s)
You're going to have to post the type of thermostats and heating/cooling devices you have. If you do have a zoned system there may be a way to interface it to a home automation controller other than replacing the thermostats.
az1324 is offline
Old 11-13-2013, 05:14 PM - Thread Starter
pboulay's Avatar
I have baseboards heaters and this is the kind of thermostat that I have:
http://www.rona.ca/en/thermostat---non-prog-electronic-thermostat
pboulay is offline
Old 11-14-2013, 01:38 AM
az1324's Avatar
Quoted: 24 Post(s)
az1324 is offline
