AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Home Automation (http://www.avsforum.com/forum/162-home-automation/)
-   -   User expandability of ADT Pulse???? (http://www.avsforum.com/forum/162-home-automation/1509734-user-expandability-adt-pulse.html)
Charles J P 01-04-2014 02:25 PM
I had played with X-10 years ago and had become interested again HA again recently. My wife wanted to install a security system so after some research, I decided to go with ADT based on what appears to be at least SOME level of user customization outside of ADT installers doing everything.
ADT is coming this upcoming Thursday to install the security system but I held off on a bunch of the extras through them because I'm fairly technical (work in IT) and have some HA experience and thought if I wanted more "convenience" Z-Wave components I could add them myself. For example, I don't need a locksmith to change out a couple deadbolts. I've installed them before. I was able to source Kwikset Z-Wave deadbolts for $150 less PER unit than what ADT wanted. I'm hoping they will integrate with the ADT system. Is the ADT system fairly open to those who are tech savvy? Can I add my own light controllers and other items? How flexible is their alerts system (I found a youtube video that gives some scant detail).
If anyone here has the Pulse system I'd sure appreciate some feedback.
Thank you.
jautor 01-04-2014 03:29 PM
The Pulse web GUI allows homeowners to add devices from the list of "supported" devices. So as long as you buy the same devices as they offer (and/or look through the drop-down lists in the UI after installation), you can add them yourself. Note that ADT won't cover those devices under their service contract (meaning, they break, don't call them. biggrin.gif)
Charles J P 01-04-2014 03:34 PM
The ADT website reads:
"We are working to provide an ever-expanding list of innovative device offerings for our ADT Pulse customers. Each time a new device is approved for use with the system, we will add it to this list.
Use of non-approved devices
Should you attempt to use a non-ADT-approved device with the ADT Pulse system, you may find that it does not easily integrate into the system, or does not respond in a way that meets your expectations. If you have problems with a non-ADT-approved device, please contact your retailer or the manufacturer for assistance. Only ADT-approved devices are supported by the ADT Product Support Teams.
It is for this reason that we strongly encourage ADT Pulse customers to use only ADT-approved devices."
I assume that's the standard corporate statement crafted to make you think if you don't pay $259 to have them install a Kwikset deadbolt, it won't work. I was hoping a system owner would chime in. Do you have the Pulse system, jautor?
jautor 01-04-2014 11:32 PM
Correct. The gear they install is right out of the same retail boxes, and you can add it through the same web UI. I've helped friends with this, works fine. Just has to be on the supported device list.
Charles J P 01-05-2014 08:28 AM
Thanks. I'll have to play around. I already bought an "unsupported" door sensor for my garage overhead door. Hopefully it pairs. In addition I was hoping the system had enough flexibility in the alerts panel to send an alert not just if the garage door is open, but if it remains open for X minutes.
jautor 01-05-2014 01:20 PM
Last time I looked at the GUI, I didn't see a way to pair a device that wasn't in their list of supported devices. I've seen some posts where folks claim to have added unlisted devices from the same manufacturer (say, another GE Zwave device), but haven't seen this in person.
The alerts and "automations" (event triggers) functionality is pretty flexible. It has a delay option from a few seconds up to 30 minutes (maybe longer?) after a trigger.
haworld 01-09-2014 09:06 AM
Just wanted to chime in here Charles, alot of my customers use ADT pulse and as jautor pointed out and as you found in the manual, as long as the devices are on their list, you shouldn't have any problems if you DIY. I must have at least a dozen customers who have used the GE Jasco 45602, 45603, and all the switches (45609/45612 and 3-way aux 45610) on their Pulse network with no problems. The entire GE Jasco line is on their list, as well as Leviton Vizia RF line is supported as well. I am currently researching the Evolve line with another customer who wants to use those for his Pulse system as well, so will post back once I know more.
Hope that helps!
Charles J P 01-09-2014 09:19 AM
The system is being installed today. I'll post back some results. One thing I notice is that there are NO door/window sensors listed. Does that mean you cannot add your own? I guess I'll find out. I purchased an Aeon Labs door sensor to use on my garage overhead door.
jautor 01-09-2014 10:54 AM
Simple wired or wireless door and window sensors should be part of any security package they're installing - they should cover all of them in the house, so no need to add them later...
(garage door sensors are a separate question, so yeah, you probably needed that)
Charles J P 01-09-2014 11:00 AM
Yeah, but they charge you (a marked up rate) for each sensor and while they do cover all man-doors, they don't put a sensor on the overhead door (that is a convenience/automation item for me, not a security item) nor do they put sensors on windows that are low risk entrance points. They rely on motion sensors to cover if for some reason someone choose to come in an upstairs bedroom window which is 40 feet off the ground due to the fact that I have a walk-out basement.
otay 04-01-2014 01:56 PM
Hey Charles-
How did your testing with the Aeon Labs door sensor turn out? I'd like to do the same. I already have Pulse, but this looks interesting: http://board.homeseer.com/showthread.php?t=153372
Charles J P 04-01-2014 05:28 PM
You cannot add door sensors or glass break sensors yourself because they are part of the security system (as opposed to part of the automation system). You can add your own light switches, outlets, appliance modules, thermostats, and locks as long as you add the same models that ADT supports.
haworld 04-09-2014 01:36 PM
Originally Posted by otay View Post
Hey Charles-
I would also like to hear if you were able to integrate Aeon labs sensor in your Pulse, Charles.
@otay - This homeseer setup works great but a couple comments. Substituting the Evolve LFM-20 for a Linear FS20Z-1 will save you about $20 a switch plus if you get an Aeon Labs Minimote instead of the Zee (which are about $200 each) that will save you another $150. Just associate the Aeon Labs door/window sensor to the FS20Z with the minimote instead of getting Homeseer (again another $249 for HS3). Your garage door opener should have the IR switch for safety if your foot is in the door blocking the beam so I do not really see alot of need for a dedicated controller unless you want one anyways or already have or plan to have a full blown HA system, thats fine. But for a standalone garage door opener, you can do this for under $160 (at least thats what we sell them for!). Of course you can get a VeraLite for $160 +/- and it will do the associations for you as well, and you can do X-10 and Insteon with Vera as well.
Bob-Matthews 06-03-2014 09:31 PM
I have been using ADT Pulse for 3 years now and have added all the z-wave devices myself. The only challenge is that sometimes new distant devices are not close enough to be detected by the system and have to be moved closer temporarily to be detected. Some devices I added are not on the supported list including a Honeywell TH8320ZW thermostat and a Evolve LRM-AS 120 VAC 500-Watt Wall Mount Dimmer switch. My assumption is that other z wave devices can be added as long as they are similar to those already on the supported device list.
haworld 06-04-2014 08:46 AM
Thanks for that! I have been waiting for someone to post their results re using other devices with the Pulse. More info for my customers. Thanks again!
dorpaul 08-09-2014 10:39 AM
ADT w/ Motion Activated camera (togather)
Hi! I am a new member who has the ADT Pulse system. I would like to add a Motion Activated camera to it, hopefully this would one device. After reading this list it seems like I would have to add it as an automation feature instead of a security feature, is this correct? My assumption is that the police would not come out unless it were a security feature? Could this motion activated camera be battery powered, as well as 110v? Would it need to be within range of my router? What camera has these features?
Bob-Matthews 08-09-2014 12:36 PM
ADT Pulse Z Wave Devices
My experience is that you can only add Z-Wave devices that are similar to those on the approved list, which are currently Lighting/receptacles, thermostats and door locks. ADT sells their own cameras which integrate with the Pulse system so those would obviously work. Personally I don't like the idea of ADT having access to my cameras (although they assure me they only can access with my permission) so I use a separate Logitech Alert camera system to monitor my home. Logitech Alert has all the features you want and connects to the internet through your powerlines. You just need to locate the cameras near a power outlet. I am sure that ADT cameras also have the features you want for an additional monthly fee will go up to support the cameras.
dorpaul 08-11-2014 06:50 AM
Thanks Bob
bbkim 09-04-2014 11:52 AM
I recently got the ADT Pulse but I do not see an option to add any z-wave device via the web GUI. Only option I see is adding touchscreen, cameras, or wi-if extender. Would you mind sharing how you installed the devices? Thank you in advance.
Bob-Matthews 09-04-2014 08:06 PM
adding z wave devices
To add a z wave device from the web interface you select the "System" tab and press the "Manage Devices" button. Then press the button that says "Lights, thermostats and more..press here to add z wave devices". Select your device from the pull-down menu which lists lighting, thermostats, door locks and controllers.
Next go to your device and put it in discovery mode. For a switch this is usually just pressing the switch, but some have instructions on how to do this. Then go back to the web interface and select "continue" and it will search for and add the device.
The only issue that you may have is your device may be too far from the router and you will have to bring it closer to get it discovered and then move it to its final position.
Bob
bbkim 09-04-2014 09:35 PM
Bob, thank you for your help. However, I do not have that option. I only have an option to add touch screens, cameras, and wi-fi extenders. I don't see "lights, thermostats, and more" option. I think I should call ADT and ask.
ManTownMedia 09-25-2014 10:07 PM
I have the same issue - no option in Manage Devices to add Lights, etc...I called ADT and they gave me the run around. They wanted an additional fee to come out to add this option when I think it should be done remotely...
Let me know if you find a resolution!
SBrady 12-26-2014 04:04 PM
Adding Z Wave Devices to ADT Pulse
3 Attachment(s)
To find the manage devices button you have to be the site owner. I found that they had made my wife the site owner. So I got her to log on and the button is there. It looks pretty easy to do as previously described.
Go to System, and on devices tab to the top right is the button "Manage Devices". Then you choose from the 4 device types, then a pull down shows up with a list of devices you can add.
I'm going to order another appliance module switch and a light switch and try it. Should get them a week or so.
Wishkid 12-28-2014 05:04 PM
Ge 45604
1 Attachment(s)
Has anyone paired the GE45604 outdoor module?
I currently trying to pair one but no luck and is in the support list, I have reset it few times and nothing. If anyone encountered similar issue and manage a work around is much appreciated.
fta123123 12-31-2014 08:14 AM
Can a Keyfob be add it to the manage devices?
Good Morning
Does anyone knows if a wireless keyfob could be add it to the manage devices? or in any other way without having to pay ADT?
jgone 01-01-2015 08:20 PM
Are there any better quality cameras that work with ADT Pulse?
The 8025 has poor resolution and it seems to need a lot of light for color video.
I would be interested in a dome for indoor /outdoor use and maybe something that has audio.
SBrady 01-16-2015 12:31 PM
Added approved devices, no problems.
I got the new items mentioned above, (all on ADT's list) and had no problems adding them to the system. As my wife feared, I have now ordered & added several more light switches and dimmers. Now thinking about the door locks.:confused:
atmv 03-02-2015 05:06 AM
I would like to add to an outdoor door sensor to my ADT Pulse system so that when my wood side gate is opened or closed, I will be notified, similar to automation for regular door sensors. However, I do not want this sensor to be enabled for the security system since I want to allow my gardener to come through the gate without triggering the alarm. ADT said they don't have door sensors that are weather resistant. Has anyone installed any non-approved device for this functionality? When I do a google search on "ADT outdoor door sensor", I see one is offered by a company called Zions Security Alarms, and that model looks identical to "Honeywell 5816OD Outdoor Wireless Magnetic Contact" that is available on amazon.
christopherglenn 03-13-2015 12:10 AM
I am using a few of the "Sensormatic Adt Oc810adt Oc810 Indoor Outdoor Wifi Camera Adt Pulse Ready" off amazon, they are running between $170-210 at the moment. They have a motion sensor, and can be setup to text/email as well as take a picture/clip when motion is detected. I am monitoring my pool, out building and inside garage with them. When the alarm is set they text if motion is detected, to eliminate nuisance texts from texting all the time. The night vision is a big plus.
Drewsak 03-16-2015 09:29 PM
I'm hoping someone can help me on here!
I've added 4 cameras and 2 lamp modules to my ADT Pulse on my own. I just ordered the GE Advanced Remote (45601). It's the only remote listed on the ADT web portal when you go into "manage devices" and select "lights, thermostats, etc".
My problem....I cannot figure out to how to program this remote to my Pulse system. As soon as I select the device in the drop down box and click continue, the next instruction is to push the "include" button...well, there is no include button on the remote!?!?! And the instructions that came with the remote do not help with programming to ADT!
So, I'm hoping someone here can provide me with a walk through on how to do this! Haven't been successful finding a walk through on the Internet for this!
Thanks in advance!
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
