Iris Single Switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-15-2014, 07:35 PM - Thread Starter
calyx76's Avatar
I bought a switch to control my outside porch light and there was a basic switch with two black wires on the back. So on the iris switch i put the ground to ground and black to neutral and the black wire to line and this is the only way to make the blue led light up and i can hear it click on but no juice to the porch light???  Do i need to jump something?
calyx76 is offline
post #2 of 2 Old 01-16-2014, 10:42 AM
az1324's Avatar
Quoted: 24 Post(s)
Two black wires on the original switch, two black terminals on the iris switch, correct? If it doesn't work one way then swap them around. Neutral should only be connected to the white neutral terminal if your switch has one.
az1324 is offline
Reply Home Automation
