Elan g! question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-05-2014, 07:24 PM - Thread Starter
Gooch707's Avatar
I am building (piece by piece) an Elan g! system for my new house.  Does anyone know if you can link an M86A and an S86P together for music distribution?  I picked up a cheap S86P and was hoping I could use it instead of a second M86A (which I already have).  The S86P doesn't have a direct connection for speakers so I'm assuming I'd have to add an amplifier.  Not really sure how you'd use the S86P....
Gooch707 is offline
post #2 of 5 Old 02-06-2014, 03:27 AM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
I don't see anything in the documents on how to connect the two - stick with the second M86A - you know that will work.
Regards, Frederick C. Wilt
fcwilt is offline
post #3 of 5 Old 02-26-2014, 08:07 PM
Robin Antony's Avatar
Yes you can link  Elan M86 and s86. by doing this you will Increase the Number of Zones but for the S86P Zones you have to use a AMP also.
S86P is controlled through Rs232 and the M86A is Controlled by VIANET port of HC Controller.
Robin Antony
Av Programmer
Robin Antony is offline
post #4 of 5 Old 02-26-2014, 08:43 PM - Thread Starter
Gooch707's Avatar
OK, I will give that a try.....thanks alot for the info!
Gooch707 is offline
post #5 of 5 Old 03-31-2014, 05:36 AM
ok
Robin Antony
Av Programmer
Reply Home Automation
